Hahah Cheers Guys ^_^
Lets see. Car has almost 500 km's on the clock now.
Tailshaft needs to be balanced / replaced with a 1 piece. God dam the 2 piece tailshafts are trash at the best of times.
After a long wait at a set of lights, about 30 seconds later the car feels as if it gets vapor lock, coughs and splutters for a second then comes good.
Apart from these 2 little.. Issues, the car has been faultless and drives really, really nicely.
It's not the fastest car around, but it feels like it would be good for a high 15, low 16. Just have to find out oneday
What else have I been doing on it. Installed a stereo into it today and some rear speakers. I have taken photos, but need a computer that takes an SD card.
It took me _ all _ day to get it sorted, keeping to the factory OCD standard. lol.
Made a list of all the thing's I am yet to put into the car ( in no order ) :
1) Front speakers in door, stealth
2) Correct door trims
3) Air ducting for fuel pump area, it works ok atm, I just want more air flow
4) Tint
5) Finish off A/C
6) sound deadening for door trims, boot lit and under bonnet
7) deep dish corn
8) Each door turns on individual fading light on floor well as well as light on bottom of door
9) Electric windows with auto one press down and up
10) cruise control
11) glove box light
12) rip out the current alarm and install one that a) works and b) doesn't shit me off
13) replace boot light switch
14) trim boot
15) upholster centre console lid and surrounding components
16) Rear airconditing from front system with rear controls - feet and face
17) Front heated and cooled seats
18) Vanity mirrors with lights in both sun visors
19) Tweeters integrated into A pillar trims, stealth
20) Subwoofer mounted in boot, other side of fuel system, behind trim panels, stealth
21) Passenger front electric mirror starting to fault, too noisy, replace
22) Rear Cup holders
23) Electric arial
24) Under bonnet light
25) power inverter mounted in rear section near subwoofer with outlets inside cabin and boot
26) 2x rear roof mounted map reading lights (one each side near jesus handle)
27) Roof mounted map reading lights for front seats with twin sun glasses holder
28) Lock / unlock all doors switch mounted in center console
29) Remote lock / unlock function on new alarm system which auto winds up or winds down all windows
30) Door warning lamp split up into 6 sections with red LEDS, relevant to which door /boot/ bonnet is open
31) variable speed wiper control knob on stalk, modified from 2002 onwards ADM Toyota
32) 2002 onwards ADM indicator / fog light / headlight stalk
33) yellow period correct fog lights
34) Finish aftermarket dash with gauges (lol forgot about that one ^_^)
35) If I could make it fit, I think a rear 4x can or bottle ice cooler like in the crowns would be fantastic in the parcel shelf
36) Retrim the boot. Did I say this above? eh. Ill say it again. Retrim the boot in my OCD standard
37) Front lip spoiler
38) Re-wire / re-light the font end, both twin lights are twin bulbs -
- low beam 55w for outer bulbs (filament 1),
- high beam is 60 w for inner bulbs + low beam lights on
- Spotlight mode with both inner and outer lights on 2nd filament being 100 something watt
39) make the exhaust quieter. hahah
40) Discreetly mount 1x foglight? in the rear, under the bar that comes on in reverse
41) Every switch in the interior needs to be illuminated when the park lights come on ;)
42) headlight on / ignition keys out / door open buzzer
43) Rear power sockets in boot and rear passengers
44) Removable Centre arm rest for rear seat
45) Parking ticket display clip in A pillar, drivers side ( thanks for the suggestion Volvo <3 )
46) JDM guard display emblems
47) Key lock surround clear stickers
48) Side external pin striping
49) New leather strip to tie up gearboot selecter inside, old one has faded
50) Master switch that turns off all the lights inside the car (service mode)
51) Hooks on or near rear grab handles for shirts / coat hangers
52) Analogue air temp gauge for inside car vs outside - discrete
53) Rear high mounted stop light
54) Power socket in engine bay for 12V accessory work light
55) Single a/m fuse box for all the different thing's ill be needing fuses for :P
56) Throw this heavy little ke70 on the scales, see how much over a Ton she weighs hahah
57) CB Radio
58) CD Stacker. Because 1997.
59) Install iluminated dice into rear parcel shelf / window area
60) Engine oil cooler
61) foot rest for drivers left foot
62) manual air bladder and pump for lumbar support for drivers and passenger seats
63) When wiper switch is pulled back, squirts water, waits abour 3 seconds then wipes windows 2 times
64) Engine kill switch
65) Discrete mounted Phone hard wired in car for tracking if car stolen, turned off and on at corrct times
66) Low washer fluid light on dash
67) Low Transmission fluid / temp too high light light in dash with buzzer
68) Low Diff fluid / temp too high light in dash with buzzer
69) Low Engine oil / temp too high light in dash with buzzer
70) Low coolant / temp too high light in dash with buzzer
71) Low clutch fluid light on dash
72) heat shield exhaust (well.. more of it)
73) Fuel door open warning light
74) LED in fuel filler area
75) Fuel lid holder on fuel door
76) Stero with blue tooth for phone
77) Rear- seats AUX or USB input for stero with remote
78) For the rear blower / Ac / heater - upgrade the front fan with something a little more upto the task of my silly idea(s)
79) Re-design front foot blower vents so they actually put air on your feet, not on one side of your leg.
I'm too tired to type any more. I know i've missed a few things. lol.
The car has just turned into a
'How much stuff can I fit into this car, make it look totally stock, keeping to the blue-car OCD standard'
^_^
Holy shit Teddy, haha. sounds like you want all the modern little things in that car! Should just buy a written off kluger or something like that that has rear A/C actually my celsior had rear a/c and are dirt cheap too, could buy a car for 1k sell engine for that and use all the little bits off it?
4) Tint
5) Finish off A/C
7) deep dish corn
10) cruise control
11) glove box light
14) trim boot
23) Electric arial
57) CB Radio
Ill check back on this thread in another 10 years.
  • Upvote 2
Is there the need to upgrade your alternator/battery capacity with all these extra electrics?
Edit: Re-read, noticed the fuse panel upgrade. :)
Edited by carbonboy
Good to see it finally on the road.
Now you'll be able come see us more often.
Oh, i sure you can find more useless things to put on your list for the car. :yes:
Off she goes, heading south.
Must admit, was sweet sorrow wheeling it out to the depot. Nicest KE I've ever driven by a long, long way.
Then again, for all intents and purposes, it IS a brand new car.
Edited by 7shades
  • Upvote 1
