Jono
Donor
    1791
Everything posted by Jono
  1. i've got one in mine.
  2. unless you get an engineer's cert. i have my 15" wheels on my engineers certificate.
  3. would look gay too.
  4. google. mini and rotary for the fwd rotary
  5. 760kg for manual 2 door sedan
  6. anything can be registered but just not legally registered if you know what i mean.
  7. the rx7 (series 6) master cylinder in my car has been modified to use remote reserviours from a dc2 integra.
  8. i have girlock calipers on mine, did 55's come with these too or did the 55 i pulled them from at pick n payless have ke70 ones?
  9. mate, what brake master cylinder are you using? i assume you've measured it up with the engine in the bay - there certainly isn't much room behind the inlet manifold in my ke20. i have the same motor as you with a cut n' shut manifold. i have an rx7 dual circuit master cylinder, only the fronts (ke55 solid discs) have the booster (vh44) and my engineer was amazed at how well it stopped.
  10. and tell me that rice canon is temporary! other than that it looks the goods.
  11. really like the orange '20s! where did you mount the booster? my mate hid his in the guard below the headlight.
  12. it doesn't have the original number plates though...
  13. i think the choice between 4age and ca18det depends on a) what sort of output you want from a standard motor b) what sort of mods you will do to the motor c) how much you want to spend d) all of the above e.g. i have put a smallport 4age in my ke20 and now i've decided to turbo it at extra expense which i'm more than happy to do. if i didn't want to spend the extra money i'd be negged and might be thinking i wish i'd put a ca18det in instead as i still needed custom engine mounts and modified gearbox crossmember and aftermarket engine management.
  14. hey, i'll offer to show you some wicked drives in sydney...if you let me have a go.
  15. it doesn't say what diff it suits.
  16. there is a bolt in rear swaybar for a ke20 on ebay at the moment. i think its probably to suit a standard ke20 diff though, :)
  17. or as that freak in Clerks II calls it: Interspecies Erotica!
  18. if it wasn't expensive to do and make a profit, every man and his asshole would be doing it. i want that 8 series BMW for 27k!
  19. do those ones have the 7 rib block trev?
  20. don't trust the writing. late model bigports as found in aw11's had red writing.
  21. did you get those headlight surrounds already!?
  22. i used an NG Pajero clutch master cylinder, its small and fits behind the inlet manifold. my mate welded in a thickish plate to support the master cylinder so the firewall doesn't flex. you need some hard line and fittings.
  23. i know a guy who built a carbon fibre toilet for a fancy yacht. the customer was billed over $20K for his troubles. ring www.tweakit.net, they make custom carbon fibre bits and bobs.
  24. i was going to wait till my motor died then rebuild with either factory GZE pistons or ARIAS before upping the boostage.
  25. i'm sure a late '74 ke20 which we were wrecking had retractable seats (possibly an option or end of line) i've used ke30/55 retractables in my '74 to get it engineered.
