Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. Sweet, looks pretty tidy! Cya in a couple of hours. :)
  2. Nice work with the dash! :P I did exactly the same thing, and it looks like with exactly the same tacho too! :D I spent ages carefully cutting a little hole in the lense bit so you can still use the shift light. :)
  3. http://www.rollaclub.com/board/?showtopic=22022&st=15 :)
  4. Yep thats about spot on. Worth mentioning that the pistons would probably need some valve releifs too!!
  5. Multiple rolls ------> Michelon Man!! ....and check out the kid I found when google image searching for the MM..... check the image name too!! :)
  6. the 4x rubber rings are probably for the spark plug tubes. :D Dunno about the fibre ones....maybe for the fuel pump?
  7. http://www.rollaclub.com/board/index.php?act=Search :D
  8. Yeah thats a liteace. Did you check if it had a 5k in it?
  9. That was a question to Redwarf not a statement. :P
  10. Yeah there's an o-ring around the dizzy shaft, I've had one leak befor. $0.50 and half an hour and it was fixed. :D Just don't put the dizzy back in 180o out. Elec dizzies go for anywhere between $50 and $200 depending on condition, there's one on ebay at the moment. Either type with do (internal/external ignitor) as long as you use the correct coil/ignitor.
  11. Check the big vacuum line to the brake booster for leaks. :D I used to be able to pump the brake pedal and make it stall because of this.
  12. Because it goes through the parcel sheft and is no diagonal centre hoop brace? :D
  13. No worries. Let me know if it doesn't happen. :D
  14. Yeah mate, that'll work. You just need to get fuel into the fuel rail (just get a barbed fitting for the rail in) and then out of the rail through an EFI regulator - but it probably has the stock one on the end of the rail. Then you just need to filter the fuel befor it it gets to the rail, mine is befor the lift pump.
  15. If you're talking about the fat naked guy in the kettle on ebay then don't bother!!! :P :D
  16. There is also a pretty big price difference between the SC12/14 and and a "non-toyota" SC like an Eaton or Paxton. Well lets let Ebay do the talking.... http://cgi.ebay.com.au/TOYOTA-SC14-SUPER-C...A1%7C240%3A1318 http://cgi.ebay.com.au/New-SUPERCHARGER-Ea...A1%7C240%3A1318 http://cgi.ebay.com.au/paxton-super-charge...A1%7C240%3A1318 But at the end of the day this is also like comparing OEM turbos like a T25 or T28 off a silvia, to an aftermarket Garret turbo like a GT28RS! Come round and have a chat about this turbo kit mate, there isn't as much work involved as what you might think! Oh and you can have a look at my new Sierra I'm buying tomorrow!! :D
  17. Yeah we seem to be going round in circles a bit here, so I'll send us off on a different tangent!! Mesh grill ---> Mesh grill!!!
  18. There's a TE27 in the states that has an S2000 motor and 6 speed. Edit: I think this is the one I was thining about, but this must be an old pic as the thing is absolutely friggin macco now!!! http://videos.streetfire.net/video/Initial...of-MY_15913.htm
  19. Yeah i'm not suprised at all, that bottom end has seen over 20psi! :D
  20. Intersted in a swap for my spitties + a bit of cash as yours have better offset? Or I could swap you your rims with no tyres, for my rims with say 50% threaders? No you can't have the advans! :D
  21. Madrolla was telling me the other day that he went and had a look at a "short course circuit" somewhere on the weekend, so ask him about that. :D
  22. You mean his good k'sev? If so it was originally an auto, hence "manual diff" comment. :D
  23. Cause I'm lazy.... http://www.daviddarling.info/encyclopedia/...ide_hammer.html
