6398 -
29
Everything posted by Trev
Here's the pics of Des's dirty engine: (The clean side, well cleaner) (Well umm i think you know what side this is)
If you can get a fully reconditioned T50 for $440 then grab it, A rebuild cost on average 1400-1600 bucks.
One final pic of the engine bay before the wiring gets fully done, Chopped out the K engine alternator and external reg harness, Pulled the coil wires out from the drivers side harness so i can extend them over to the passenger side, Removed excess wiring. To do list: 1. Hook up tacho and guages. 2. Tidy up and reloom wiring. 3. Wire in fuel pump wiring to the back so its all good to go when i get the pump. 4. Make up earth sraps and power wire to the starter. 5. Install a distributor controller or buy a AE82 4A-C dizzy.
Looks tuff as, I bet the 2TG goes well in it.
Ha well would you beleive its also a key turner, I'm still cleaning up the unused wiring but she winds over very happily.
No worries.
If you want i will take a pic of it on monday, I still can't believe there was a 4age that was covered in more oil than mine, LOL.
That means i gotta take the bloody rear wheel off, Ha.
Well it will be worked on once the layer of power steer fluid is removed :abuse: This thing should hammer nicely with the bottom end and head combo.
My car was built from a brand new shell by TOM's Japan for Tom's Toyota Racing GB (England). its first race was Spa 24 hour(Belguim) in 1987. After winning its class in the British Touring Car Championship in 1988 & 89, it came to Australia as part of the Bob Holden team. The car raced in the Aust touring Car Championship from 1990-93. When GpA racing finished it had no class to race in so it was safely put away till I got it going again in 2007. It is still in the same format & livery as it last raced at bathurst 1993 Engine 4AG "small port" . Motec computer and quad throttles. extensive internal development transaxle C52 with TRD close ratio gear kit and LSD. short shifter brakes front AP racing 4 piston alloy calipers and full floating slotted vented rotors rear FX-GT rear discs with front calipers. Two master cylinders with adjustable pedal box for balance. no booster Suspension all custom made. front. alloy hubs with alloy cased KYB coil-overs. adjustable for height, bump & rebound. TRD rose-jointed wishbones TRD adjustable sway bar rear. factory hubs with alloy cased KYB coil-overs. adjustable for height, bump & rebound. TRD rose-jointed wishbones & tie bars TRD adjustable sway bar wheels 5 x 6.5 BBS, 16 x 7" TTA magnesium. all centre lock cooling stock fuel tank custom alloy outer tank with internal bladder. 65 litres. dry break fillers Interior TRD race seat, TRD instruments, TRD steering wheel Alloy roll cage original dash frame etc. rear seat & hood lining removed plumbed in fire extinguisher 6 point harness belt (Quad throttles not shown, Small port manifold installed for testing) I will get more pics on monday and maybe a vid of it running.
Mazda 6's and i think a few others have factory soft/loud mufflers that open up more when you get higher in the rev range.
K Series TRD Camshaft In English Try that.
Well I'm not quite finished, Still needa buy a fuel pump and extractors, All the other stuff i need hopefully i will be able to mod or make custom. Engine is finally in but i forgot that the KE70 has a different gearbox mount point to the AE71 so the gearbox x-member i have is useless, Some pics:
Nah the paint was just shy of 20 bucks, You should know you were there :abuse: Its all the new stuff i have put into the car that has made me go over, The exedy i have aint got much good life in it but i put it in there just to get it together but atleast i have spent under what the 4agte owes me froim the sedan so thats a good start.
Thanks, Got the helicoil kit today but was too flat out to do anything with it, Going into work in the morning to fix it up and bring it home, I will be very pissed off if i can't bring it home, It wont be running straight away as i still gotta rebuild the carbs, Get extractors and organise a dizzy controller, I have also blown my budget out so its now over the 2k mark but shit happens.
1. Lighten flywheel.Didn't bother doing it. 2. Install spigot bearing (should be arriving tomorrow).Done. 3. Clean cams up.Done. 4. Install flywheel and clutch assembly.Done. 5. Fill injector holes.Done. 6. Install helicoil into head. (Gotta get the right helicoil now) 7. Braze up cooling pipes so they are flared, Have been cut up into required lenght already.Just going to double clamp the hoses. 8. Fit new timing belt and front cam cover assembley aswell as harmonic balancer.Done. Well the helicoil kit i needed decided to go walkabouts so now i gotta order one and hopefully it will arrive tomorrow (I want the engine in this weekend), Cooling system is done but i will buy new hose for it.
Thats a big difference, Pity bout the brackets but I'm sure you can sort something out.
I took this the other day at work, I had a drain tray under a car so what you see is a mix of degreaser, oil, grease and water.
1. Lighten flywheel.Didn't bother doing it. 2. Install spigot bearing (should be arriving tomorrow).Done. 3. Clean cams up.Done. 4. Install flywheel and clutch assembly.Done. 5. Fill injector holes. (Prolly Tomorrow) 6. Install helicoil into head. (Prolly tomorrow) 7. Braze up cooling pipes so they are flared, Have been cut up into required lenght already. (Can do these anytime, don't need the engine to do it now) 8. Fit new timing belt and front cam cover assembley aswell as harmonic balancer.Done. Was going to bring it home today but it was getting late, Tomorrow it will be as its ready to go in, Here's 2 pics, Sorry bout the first one i moved my phone when i was taking it.
Atleast you can tell all ya other mates that you got a brand new corolla for your birthday and mummy and daddy didnt pay for it.
Is that a solid rotor, JDM's came with vented.
Bah engine is still at work, List of things to still do: 1. Lighten flywheel. 2. Install spigot bearing (should be arriving tomorrow). 3. Clean cams up. 4. Install flywheel and clutch assembly. 5. Fill injector holes. 6. Install helicoil into head. 7. Braze up cooling pipes so they are flared, Have been cut up into required lenght already. 8. Fit new timing belt and front cam cover assembley aswell as harmonic balancer. HOPEFULLY this should be done tomorrow as I'm hanging to get it in the car, I only get 30-40 mins in a lunch hour to do anything to it and then from when i finish at 5 till whenever so i don't get much time to do shit.
Slim was here earlier today, I said i was going to paint the chassis rails and radiator support black, Well he pursuaded me to do this: It don't look as good in the pic. There is no engine going in tonight, Only the top of the FWD sandwich plate fits (I was told that may be the case) so I'm going to littleredspirits tonight to get his 4a - t50 sandwich plate and hopefully i will finish the engine tomorrow then, Today wasnt the best as i only had 3 hrs on the engine and i couldnt use the compressor as we arent in an industrial area so here is what i got done: Before you ask what is up with the engine paint: The paint on the engine is still wet.
