Everything posted by Banjo
Ke25 Electricity problems.
Hi Rune, First thing is to get yourself a wiring diagram for your KE25. They are a bit of a rats nest, trying to read, but if you work backwards, it's easy to trace out a particular circuit that is not working. I have a Gregorys 122A Manual, covering most KE20-25 models from 1970 - 1978, which didn't change very much, at all. The fuse block on your Rolla, below the steering column; does it have 8 off, or 10 fuses ? You have identified 3 off circuits that are not working, whilst the ignition is on. (blinkers/wipers/& reversing lights). Lets start with the reversing lights. The legend says these are items nos: 72 & 81. The wiring diagram indicates LH & RH reversing lights are connected together, & go back to item no: 15, which the legend says is the reversing switch, (usually found on the top of the gearbox. The other side of this switch, goes to fuse 1 on the fuse block. The wipers, item no: 19, are powered by fuse 5 on the fuse block. LH & RH indicator/blinker lights, items 73 & 80, both go back to the indicator switch, which is item no: 64. The power for the indicator switch comes from the hazzard switch, which is item no: 62. The hazzard switch obtains it's power from fuse 4 on the fuse block. The "supply" side of fuse 1 & fuse 5 both get their power from the ignition switch. Fuse no: 4, gets it's power directly from "fused link", next to the battery terminal, as the hazzard lights must be able to be activated, without the ignition on. However, that same "fuse Link", feeds power to the ignition switch, which powers the other two items you said are not working. I would suggest you have a single issue, that is causing no power to be fed to all these three devices. It could well be the fused link itself. That would certainly cause the problems you describe. With a test lamp, with one side attached to the -ve terminal of the battery, I would start at the battery +ve terminal, & then go to the other side of the fused link, ignition switch +Ve feed, & the supply side of the fused box. That will probably help you locate where the circuit has gone open circuit. A simple way to not get confused by the mismash of the lines on the wiring diagram, is to draw just the circuit that is not working, on a piece of paper,& then work through that. Let us know how you go. Cheers Banjo
Rare - Rare Find !
I know this "rare find" is not a Toyota, but it is a remarkable story, despite the video quality not being particularly good. https://www.youtube.com/watch?v=YEJxc1r_dtI They are still out there ! Cheers Banjo
Rare - Rare Find !
The Toyota Landcruiser, on auction, mentioned earlier in this thread, closes bidding within 24 hours. It is sitting at $ 18K atm.
ke25 dash wiring issue
Hi Joao, Glad that you got it sorted & working, & that we were able to assist in some way. Cheers Banjo
I just found an olde KE20/25 wiring diagram. It has a tacho shown. According to the wiring diagram the white wire with the black stripe goes to ground/earth/chassis. The black wire with yellow stripe, goes to 12 volts supply on the fuse block. Actually on my wiring diagram marked as simply a "yellow" wire. The black wire goes to the "points" -ve terminal on the ignition coil. So power up the dash, & check out which terminal is ground, & you should be away. Trust this assists. Cheers Banjo.
Hi Joao, This shouldn't be too hard. There are only three (3) wires from the tacho to connect. One will be +12V; one will be ground/earth/chassis; & one will be the tacho input signal. The ground/earth/chassis connection, will usually be a black wire, or white with black stripe, as they are the Toyota wiring colour standards. It looks like the black wire (already connected) is correct, as there is no where else it could connect, because of the black wires length. You could check this by powering the dash assembly & testing with a multimeter or test lamp, that the point where the black wire is already connected is ground. I am guessing that the black wire with the yellow stipe will connect to the terminal marked IGN 12V. The tacho will only be powered when the ignition is "ON", & the remaining white wire with black strip, is not long enough to reach that point. However, there is always the possibility that the tacho is powered by the 7V connection, & either of these two wires would reach that point. It appears the input is connected to the unmarked termination point, directly above the Japanese Toyota symbol, in your first photo. All this depends on whether the rear PCB of the KE20 & KE25 dashes are laid out the same. I'd be putting the tacho back into the dash panel, you removed it from, & connect it up as it was. Then take note of which wires colours were connected to marked terminals, like +12v or 7V etc. Unfortunately, I don't have a KE20/25 dash here I can check this out. Try what I have suggested, & if that is not successful, come back, & we'll research this further. Cheers Banjo
Rare - Rare Find !
Slow ! You bet. In another life, I worked in the highlands of PNG, for a rural supply company. It was mainly coffee production in that area. The company supplied me an FJ55 wagon, company vehicle, like the following . . Actually, it was exactly the same colour scheme as this one above, but was battered & constantly dirty, as there wasn't a sealed road in sight, & the rainfall & mud were constant, in that part of the world. The FJ55 was as rough as guts to drive. A 4 hour trip in it, made you feel like you'd been in a milkshake machine. However, they were unbelievably reliable, & just never stopped. I used to regularly cross rivers with the water just over the windscreen wipers. We achieved this by carrying a great big sheet of plastic coffee film, used to place on the ground, to dry coffee. We used to lift the bonnet, tuck it in over the radiator, & close the lid. The plastic film was then tucked in under the bumper bar, so that it covered the grill & radiator completely. You'd then run at the river, & hit the water hard, so you created a bow wave, which if you kept it moving, didn't allow the water up too high in the engine bay. Worked most of the time. If it didn't work, there was always a rope in the back, & a lot of locals to help. Cheers Banjo
Rare - Rare Find !
So the Corolla sold last night, & today another Toyota pops up on Collecting Cars auction site. Not a Corolla, but a 33 year olde Toyota Landcruiser with just 36,486 klms on the clock. https://collectingcars.com/for-sale/1988-toyota-land-cruiser-cab-chassis-pickup First bid just popped up, @ $ 3,500. And for those of you who are still jealous that Colin has had a drive of the Yaris GR, then you must watch this video, to understand what all the fuss is about. https://www.youtube.com/watch?v=Rr1eJJhnsLQ&feature=emb_rel_end Cheers Banjo
Rare - Rare Find !
There were 9 more bids in the final hours of this auction, & it eventually was won, by a bid of $ 12,750. Hope the new owner is very happy, & joins our forum, so we can learn what the plans are for it. Cheers Banjo
Rare - Rare Find !
There is a note on the auction website today as follows . . . Anyone know what "Reserve Lifted" means ? It sounds like it had a reserve of $ 10K on it, & as it has surpassed that mark, the reserve has been met. However, could it mean, that the reserve has been increased/lifted; & if it doesn't reach that newer/higher amount, the highest bidder does not necessarily win the auction ? Cheers Banjo P.S. Just got an email from Collecting Cars, with link to the website that advised, & answered my query as follows. NO RESERVE
Rare - Rare Find !
Hi Colin, More info please. Review, impressions. You've done something most of us mere mortals will never get to try. The 1979 Corolla, which was the subject of this thread, just broke the $ 10K mark today. There has been a doubling of the number of bids today. 11 this morning. 21 tonight. There is still 24 hours to go. Watch this space ! The Rolla is now assured a selling price of at least 3 times, what it was worth new 42 years ago. That's a lot of years to wait to triple your money/investment. If you had invested $ 3000 for 42 years ago at 5% annual compound interest, & never touched it, it would now return you $ 24K. We'll have to get the new owner to join this forum; but then, in the condition the Rolla is in, he/she won't need much assistance. Cheers Banjo
Rare - Rare Find !
Hi Dave, Litchfield apparently think the "hype", is warranted. https://www.litchfieldmotors.com/toyota/gr-yaris/ No ! Go the full hog; aim for a WRC 21 version. OMG ! They can even levitate ! Cheers Keith
Rare - Rare Find !
Hi Pete, I read recently, that a proportion of the sales of the new Yaris GR Rallye, were for investors, just snapping them up, for investment, as they believe, being a limited edition, the car will be most sought after, within a few short years, & achieve that "extremely desired classic" tag, that we know exists with say the AE86 Series. https://practicalmotoring.com.au/car-news/hot-toyota-gr-yaris-rallye-launches/ I've read a few of the early reviews of motoring journalists, who have driven them, & it does sound like it is a winner. You just need somewhere, between $49K & $59K, depending on what month you purchased it. Apparently, there is a waiting list. Cheers Banjo
Rare - Rare Find !
Hi Pete, It now Sunday night, with 3 days to go, & there have been 9 off bids, & it's up to $ 6.5K. It struck me that is about double the price this car sold for, when it was brand new. I had a KE35 2 door coupe once, which I bought off a girl next door, where I was renting. First weekend, I cleaned it from top to bottom, (inside), as she used to cart her cats around in it. In the back of the glove box, I found all the original paperwork, including the original receipt of sale, when it was new, which indicated it sold for a tad over $3K, off memory. Cheers Banjo.
Rare - Rare Find !
Note it is up to $6.2K Sunday morning, 28th Feb.2021. Would not be surprised if it got up as high as $15K, if the right person, somewhere in the world, really wants it. There was a case many years ago, when I was looking for a "similar state" Corolla of the 70s vintage. I came across one on ebay, & starting bidding. It was at Port Macquarie, NSW; original, one lady owner, low mileage. You know the score. I had it in the bag, until the last 15 minutes of the auction, where another new bidder joined the fray. I played the game & thought I had it, but was pipped/nipped in the last few seconds, before the auction closed. As an ebay bidder, you are able to see after the event, the details of the other bidders. To cut a long story short, this winning bidder was an international car buyer/broker. After the auction, the car got transported to The Netherlands ! There is a lot of interest in the following journalistic contribution on Caradvice.com.au website atm. https://www.caradvice.com.au/919581/old-cars-belong-in-museums/ The article itself is one thing; the replies & answers below are also a good read. It's a topic that will resonate, with many on this forum. Cheers Banjo
Rare - Rare Find !
Hi Cashed Up RollaCub Members. He is a very original 1979 Corolla 4 door sedan, located in Melbourne, currently for auction on CollectingCars. The auction closes on Wednesday 3rd March. https://collectingcars.com/for-sale/1979-toyota-corolla-cs I'll say no more. Just look at the 180 pics of this vehicle on the auction site, & read the full description. It reads like a Rollaclub members wildest dream. Cheers Banjo
Does lightening Your Car Make It Go Faster ?
If you live in Melbourne's north western suburbs near Caroline Springs, you can take a 45-60 minute joy ride in a Delorean, for $ 299. https://www.redballoon.com.au/product/delorean-time-machine-joyride/MUS005-M.html?gclid=EAIaIQobChMI8viQ9KfR7gIVja6WCh3O5ATNEAYYAyABEgIxgfD_BwE Cheers Banjo
Hi Pete, No it's not a DeLorean ! A bit closer to home ? Tempted ? It reminded me of a post I put up on here a couple of years ago. https://www.rollaclub.com/board/topic/73779-delorean-model-dmc-12/?tab=comments#comment-712934 Actually, I just put the word Delorean, into the search engine on Rollaclub, & found there are 14-15 posts mentioning this classic. Actually, I never posted an update to my original post, after seeing one in the flesh; up close in Canberra, a few years ago. I was down there again, just before COVID-19 hit, & was walking across the underground carpark, in the complex where my son lives; & there was the Delorean again, but this time there was someone working on it. We walked up & started talking to the guy, who was the owner. He had a USA accent, so my guess was he was stationed in Canberra. He told us all about the car, & what he had done to it, over the past year or so. I told him that I had seen it on TV, as when our PM (Malcom Turnbull) resigned & went to advise the G.G. in Canberra, the ABC TV crew were at the gates, of Gov House, & picked up a Delorean passing by. He advised it wasn't him; but did advise, that there are two (2) Deloreans, resident in Canberra. it must have been 45 mins before we eventually said our goodbyes; but reinforced to me, how passionate some people are about their cars. Cheers Banjo
You Be The Judge ! Cheers Banjo
Ke70Daves New Euro Toy
We all know Dave luvs his Euro Toy (E30), but I wonder if he is so dedicated as this guy, who when he put down his last spanner, & drained the oil for the last time, . . . . had to take his Bemmer with him. (well a replica anyway) Now there's a good idea for my olde KE30, if my kids don't want it. Instead of the usual Dust to Dust, Ashes to Ashes, it will be . . . . . Rust to Rust ! Cheers Banjo
Regulators - what’s the difference
As the u-tube video above relates, the reason we need a big ampere/hour battery, is for just one thing; to start the car ! Once the car is started, you really only need a quite small battery, as the power/current consumed by the car once running, is very small, by comparison to starter motor current, which can easily be supplied by a small alternator & smaller battery. I'm olde enough to remember my dad using a crank handle, to start our Morris straight 6, when it had a flat battery. It not only took a lot of effort, but if it fired & "kicked back", it could really do some damage to your arm or wrist. The reason the starter motor is large, is that it is working against the compression in the engine. Lots of remarks on the net that we only have another 10-15 years, before the demise of I.C.E. motors. I read an article recently, in which it claimed the ICE motor is not done with yet, & there are still those developing new features, to prolong it's life. One that caught my attention was a "camless" engine, where the valves are opened by hydraulic pressure, controlled by electronically controlled electric valves. They have built running engines, that rev to 20K rpm, using this technique. One feature that caught my attention was the fact, that the starter motor size could be greatly reduced, & hence the size of the battery. The technique was that when starting the engine, all valves would be opened except one. Once it kicked in, the other cylinders could be brought on-line, one at a time. Crazy when you thing about it, that we lug this very heavy battery around all day, simply so we can simply start the car, when it stops. https://youtu.be/S3cFfM3r510 https://www.youtube.com/watch?v=Bch5B23_pu0 Cheers Banjo
Hi Pete, I could bore you to tears, but this video describes just about everything regarding automotive alternators. https://youtu.be/jdSKlg80DjU The only difference you will come across on our Rollas, is that early Rolla's had alternators, where the regulator was a separate unit, & was non electronic. Later model Rollas have alternators, which have an inbuilt electronic alternator. Alternators, are generally sized by the maximum load current they can produce. Maximum electrical load is usually required during night driving, when lights & other electrical loads are at their greatest. One of the best mods you can do to a Rolla, is fit an alternator, with a greater output. Early model alternators fitted to Rollas, produced 30 - 35- 40 amps max output current. Best mod I ever did to my KE30 2 door, was to fit a Hilux alternator, with 85 Amp output. Others on this forum, have used Holden Commodore alternators, with up to 120 amp output. Cheers Banjo
Brake Hoses
Are you just doing the front wheels, or plus the one on the diff, at the back ? Cheers Banjo
High idle
Hi Lewis, I've not come across this before, so can't offer much help. However, if you Google your query, Google offers the following . . . . Hope that helps. Cheers Banjo
Radiator/Cooling Help
Hi Misael, I know just where you are coming from. Your totally original acquisition looks to be in extremely good condition, for it's age; & results from the extremely low usage over it's life, by a "little olde lady", who only used it to go to the shops. I have no idea, how much a car like this is worth in the USA, but it is the land, where if someone wants something, they will pay dearly. It may be a case of thinking outside the box. What if: You had the car professionally cleaned & polished, & brought back to totally best condition, so the car is genuine, & is in excellent appearance & presentation. Possibility no: 1 You take it to a car show where there are lots of cars of that era or genre, & lots of people viewing, who are potential buyers. You put a for sale sign in the window & see what transpires. Possibility no: 2 You approach Toyota dealerships, with show rooms, which might jump at an olde original, immaculate Corolla, to place on the show room floor as a drawcard, & talking point. Possibility no: 3 Sell it to a business, who wants to be recognized, while it is used for small deliveries, or the like, to which they can add their brand name, & a logo like "Good Olde Fashioned Service" or the like. You might be pleasantly surprised how much it may be worth, to the right person. You could then use those funds to buy a project car of your choice, with which you can learn, & have some fun with. Cheers Banjo
