4772 -
64
Hello Fam. I did get the AC to work, but its lost its gas in the lead up to christmas so I need to fix it again. Have just been enjoying it a lot lately. Maybe too much. Been giving it hell around the cane fields lately. Lots of fun. Have just clocked over 380000 klm on the odometer meaning its done about 57000 klm since the 2azfe conversion. I have lower klm odometers and about 6 sets of clocks for it but I like having the original one in there so I know the klm on the chassis. Have been fiddling with the tuning, have a pretty great startup now, and the plugs read brilliantly. Havent been on a dyno since 2020. I have enough parts to build a tuff motor now. Kelford cams, 286/278 duration and added lift. My CP 11 to 1 pistons, some molnar forged rods and some supertech valve springs, I have a couple full gasket kits as well. Should be a mad machine when I get around to that. Just thought Id throw in an update for the rollaclub family! peace.
Time for an update because I have some work planned. Have collected everything I need to put Air conditioning in. I purchased or saved over the years; -a new oem Denso condenser - a new Spal fan for the condenser - working 2az AC pump from my 78000 k donor car and the pump ends of the AC lines. - all the OEM AC parts from the car including all the standard soft and hard lines, mounts, wiring to connect it up under the dash. - Spare AE86 heater switch block as mines a bit broken in the car. - New AC faceplate decal - New OEM heater core from Japan. I decided that its not worth just doing AC, I will fit a heater too. Things I need to re engineer to make it work; 1. Relocate oil cooler and lines. Make new brackets for it and possibly ducting. 2. Mount the AC pump and design the new belt and tensioner system to spin it. 3. Decide what kind of heater tap to use, where to mount it, and the hose path for it. I'm considering either an electric heater tap with a hidden micro switch in the AC switches to operate it, or a relocated cable setup. I think electric tap will be simpler with what I have going on in the bay already. Have treated her to a few missing parts as I've been able. I put in a rear hatch trim board which I bought new. I finally found a rear demister switch and bought it new also. Have replaced the headlight knob that had no writing left on it with new. I bought a top windscreen trim (again) as I will have to do a screen at some point maybe to re register as its got a big stone chip the size of a 10 cent piece on the passenger side. The old top trim has never fitted right as the windscreen guy didn't mount all the clips as needed so it just flies off at 100kph. Has happened twice now once on the Bruce Highway and was never seen again. I also bought a new rubber grommet for the bonnet post so it doesn't rattle, and a fuel tank pickup gasket to change next time the tank comes out. I have some folded and cut to size metal to make a new lower passenger seat rail to match the drivers and allow me to get rid of the modified ke70 rails it has. I also have the bride type seat slider to adapt to it. Basically building a copy of the drivers rail I have but reversed. Front wiper motor is pretty sad so will be swapping that to a better one. Also going to fit the rear wiper washer demister setup for the hatch as it rains a lot at the moment and Id rather have it in the car and I have all the switches finally. Car isn't currently registered but will be re registered after all that's done. Also lowered it and bought a better Jack so I can get under it at the lower height.
From memory the ae86 stock pump is just an in tank HP pump, not a lift pump so it will have to hold whatever pressure the rail holds.
I made new oversize fuel lines for my first ae71, was not worth it. Maybe the least enjoyable mod I've ever done. Just write down the pip sizes for feed and return, take the pump bracket with you, ditch the expensive raceworks stuff and go to an industrial gasfitting supplier like IFS and just buy what you need off the shelf. They have everything, hose to barb, taper fittings, banjos, hose adapters, push lock, metric imperial and they can make a fitting if you're really stuck.
Es posible que deba publicar una foto de la caja de cambios o buscar cosas en el catálogo de piezas y confirmar lo que tiene.
You have a speedo drive that suits the automatic final drive ratio.
super tidy
Not to mention the leather seats!
Yeah make mounts to suit your chassis. Custom headers and inlet. Y starter ring gear and bellhousing. Have a bellhousing set for sale if you're keen message me. Use a W transmission. I have a w57 now but will put a w58 in soon. Fuel system, wiring, ecu, tuning etc.
Aussie 82 ke70 mud guard (amily)
LittleRedSpirit replied to Michael Dundee's topic in General Discussion
Dealer option at best -
How To Tackle That Engine Conversion-
LittleRedSpirit replied to altezzaclub's topic in Engine Conversions
I've seen so many adds for sale lately priced on potential. Like a stock roughish VK executive with a HSV GTS motor, on a pallet next to it, asking 25k. With a comment like, just needs to be dropped in. lol. Car is valued at 5k, motor at 6k, how do you come up with 25k. People get in too deep, cause its easy to spend if you're an idiot with cash, but idiots cant fix or finish anything. Hows the ae86 on FB marketplace with the full ra65 engine, box and interior, with positive offset wheels asking 25k. Fucking vomit spec. Where I come from people like that get slapped. -
Looks like old mate lives in QLD so all that engineer stuff doesn't apply. Just get a mod plate and follow adrs when you build it, and you'll be fine. Thankfully QLD motor trades are deregulated and there's even 6 shires where you dont ever require a roadworthy. My mod plate for 2az86 was about 200 bucks, and it covered engine, suspension and diff, cage and seats.
Quick update. House is half built. Roof is on. Cars been sweet as can be. No real issues to report, just wear and tear from all the roadwork between here and Brisbane. Copped some gravel and rocks from trucks coming in and out of the quarry north of Gympie. Was lucky to not experience much more serious damage. Front bar took the brunt, and ejected the paint. Gave it a wash today. Much overdue.
Sounds like a fun little project. Did you dribble a couple ml of oil into each cylinder to try to lube up any stuck rings while comp testing?
I put it all back together minus the grill and sent it for AC repairs. It had a rubbed through a hose from my big fan that I added to the condenser. I removed the big fan for now, and will replace the 400mm unit with a much more appropriately sized 300mm one. Otherwise its all fixed mechanically now and the AC is 3 degrees C. If I'm being fussy I might grease the steering rack and tie rod ends. The suspension is performing well. Next to no body roll, or pitch and bounce with good shocks in it. The Konis are in the front now dont know if I mentioned. Just need to find someone to spray the top of it now.
Im so not moved by the GR yaris.
Have now done the auto fluid and filter as well as resealing the auto oil pan with a new gasket. Its got new Penrite 85 140 diff oil too. Ive fitted a rear wheel cylinder and bled brakes and fresh fluid right through. I test drove the car and found the front shocks were still in need of doing so I put my Koni Sport adjustables in that I had on the shelf, set 135 degrees back from full stiff. Car feels lovely to drive now, took a good long drive up the highway and it was superb. It now needs the AC fixed, and Im going to hand it over to a painter to redo the roof, bonnnet and boot areas as I dont have the equipment to do that here. Then it will be regretably up for sale.
Ok, there has been much done on this. Been scratching out, rust converting and smoothing out crows feet in the paint. Have removed the power antenna and bought and aftermarket replacement. Have removed rear shocks and purchased a pair of monroe GT Gas shocks for it. Just standard ra65 shocks. Have the rear bumper removed, and Ive been straightening the shell with the heat gun, twisting the corner of the reo straight, and fixing rust in it. Theres a seperate part that mounts the number plate lights inside the skin, it was super rusted out for some reason, and the threaded posts that let you bolt on the skin, well 2 were so rusted they snapped. I drilled them out, replaced them with m6 allen head bolts and ground down a couple nuts to create the stepped mounting they needed and to let me attach them properly. The rusted out part that mounts the lights was then ground off the strip with the threads, and replaced with a piece of zincanneal that I had folded up by levs fabrications here in town. Instead of welding to the surface rusty metal strip that it attaches to, I used a thick gooey epoxy, to seal over any rust in the union between the pieces, stopping cavities that may increase rust problems. They also replaced for me the metal piece that secures the skin all the way accross under the bumper. Mine had been torn away and stretched and was rusty from damage to the bumper anyhow. I never intended to get into the bumper, but I always noticed some suspiciously flaky paint on this lower corner, and in the three years my mate had the car it had started lifting, so when I sanded it back found an old repair, had to remove the bumper to fix the paint there so I just decided to go for it and make it nicer. I redid the blackouts on the bottom with a Upol power can, pretty amazing quality rattle cans those Upol ones. Ive got the arch trims out on the right side, theres no rust in there. Cleaned all underneath it. Pockets are perfect, I repaired one bit of rust under a sill trim, had to just plate over the outer layer and reproduce the square hole for the body clip. Its all filled over painted and has the blackouts redone too. I had the rear screen removed, and repaired the rust that started to come back in the lower right corner. Did a much more thorough job getting any pinholes to be filled with weld, and did great prep with PPG etch primer, filler, sealer and topcoat now. Been buying matched cans from signature refinishing supplies that work great. Have a fairly good sized rust patch just isolated under the drivers door, in the shut of the door itself. Just a fairly simple shaped area that needs to be replated. Bit of a bitch cause I need to remove the door to do it. So the to do list as it stands now is as follows: - Reassemble rear bumper and install. - Repaint roof and bonnet to finish the crows feet repair. - Install the power antenna for the radio. - Install the condenser and new AC o-rings, which I have a couple assortments of thanks to an ebay miss-click. - Put the grill back in. - Change the wheel cylinder on right rear as its leaking, have the part here. - Brake fluid flush and replace. - ATF service and trans filter. Stuff Ive done so far: Waterpump, oil, filter, visual timing chain inspection, new front crank seal, resealed top cover and half moon plugs, replaced all vac lines and deleted the EGR, air pump and emissions crap once and for all, including the metal vac lines array. Resealed and painted the boot seal area. Rust repairs under the rear screen and repainted. Rust repaired the sill. Repaired old crash damage at back bumper. Replaced the top radiator hose. Flushed radiator, new cap as the old one didn't hold pressure, washed out the rad overflow.
I know you all enjoy a good love story, especially when it comes to an RA65. I bought her back, my mate was ready to upgrade so now I own her again. Since I owned her he's done about 30,000ks, its about 142,000 now. It needs a general tidy up. I'm looking at doing the timing chain, waterpump, shocks, some bushings, greasing the rack, and detailing it. Needs a few small touch ups, maybe one or two small rust repairs. Nothing serious. Just going to do the work, then drive it around and try sell it I guess. Jst wanted to get my hands back on it and tidy it up. oh and the AC has stopped working so will also fix that up ASAP. We've already done front brakes and bearings, and the alternator with Medicine mans help while my mate owned it.
Looks awesome Dave, all the better for it. I think youve got your terms backwards with the refrigeration bits, the condenser is in the front of the car, the evaporator is under the dash, unless im learning something. Ride height is perfect yes.
Man its great up here, been making a few friends, I love it. The bank just approved our finance to build starting next month. Weve bought 1.2 hectares, 12,000 sq Metres, thats about 32 Brisbane house blocks, and were just dropping a big 3.5 bed home right in the middle of it, with a 12 x 18 x 4.8 high shed to follow soon after.
I've ordered a replacement Bosch 984 pump. I've rewired the loom for it, and its 25 amp wiring all the way. I reduced the fuse from 30 amp to 20 AMP so that if the wire heats up I will know and it will blow before it burns out the fuel pump. I further shortened the wiring, each circuit is about 1.2metres now, defintely not going to experience voltage drop with that. I also stripped a shitload more paint off under the ground strap where the fuel pumps also ground. I drilled a hole through the boot floor directly above the pumps which also happens to be right below the fuse and relay that powers the fuel system, and applied a toyota grommet to it. If it fucks up now I'm seriously wondering what I could do. Ive wrapped the wires in self closing braided insulation. I shook the old fuel pump out to see if it had contaminants in it, it did have a few bits and pices in it, a few very small bits of rubber debris from the lines, and one concerning steel chunk about 1mm accross. Reading about the pumps, thats not good for them, although it would have just failed outright had that ruined it, not been worse over time while driving. Just to be sure Ive got a new z200 fuel filter to replace too. Im keen to get the pump, the car is ready to just slip it in and drive away, Ive even got the right tools, and equipment there all piled up ready to do the work under the car.
Had the local locksmith fix the boot lock so it opens all on the same key and I dont have to use the popper in the car to open. Way more convienient! Fuel pump is finally dieing, gonna change it before it stops altogether, its dropping to about 1.6kg/cm2 from 4.4kg/cm2 when hot, and the relays are getting to almost 90 degrees. I think its more or less burned out from running with too much voltage drop inthe past. I'm gonna just replace it with another Bosch 984 and rewire it with 2 x 30 amp circuits instead of 2 x 15 amp circuits, and it will hopefully hold the pressure now. I have a good sense for it now, if the car starts to get extended economy and stalls when stopping at the lights I know its going away again, and after a brief while where it was good, its doing what it did before when I realised I had voltage drop. Might even consider a different brand of pump.
Still playing steering. Have found you can buy the rack preload stopper and spring for 35 bucks, so Ive ordered a set for me and a set for a mate that needs a rack and pinion conversion in his t18. Stripped a rack for him and Ive drilled and tapped a grease nipple into it so its easy to grease in car. Waiting for bits to arrive in a few weeks so we can rebuild the rack and fit it up to his car on a ke70 crossmember. Went to a local Harvey Bay meet the other night. Some nice cars and even nicer people up here. Everyone just stoked to be there. All kinds of cars from series 6 rx7, silvia with a built rb25, vk v8 308, stroked ls Holdens, Mazda MPS, Hiluxes, r34 4 door skyline, you name it. People just love cars here and they all seem to get along.
