2185 -
22
Everything posted by coln72
typed the number on the back of your alternator, 921096086, into Cooldrives website and it came up as a Bosch 70A alternator to suit XP-XD Falcons Part number BXF1238A. Also came up with a Jaylec brand to suit Pulsars and Astras.
Aftermarket Aluminium Radiator Core/Shroud/Fan
coln72 replied to Banjo's topic in KExx Corolla Discussion
I know all about oil getting flung to one side of the motor..... -
am I missing something or is that a pump for the dry sump set up.0 -
Nothing as exciting as that in my history. Started, like all my mates in Corollas. Had the above KE35 in many many states of tune. As mentioned, swapped it for a HZ ute. The Corolla was used by the old man as a trade in on a Patrol. Traded the HZ in on an ED Futura as the ute was killing me with fuel costs and the missus hated the ute. Then purchased a new VY Berlina wagon, with lots of options. Loved that car but needed to offload it when bubs no. 4 came along. Now on my 2nd Carnival - great cars. Also in the mix have been a couple if Ford Festivas and a KE20 club car. Not counting all of the wrecks bought to keep the KE20 alive.
wasn't bad for rust, but it was resprayed a custom red after an accident. My uncle refused to paint it the original colour he hated it that much...... In the end I swapped it for a HZ ute (owned from new by my grandfather had 60000km on it). Wish I still had both.
unless you run coil overs there isn't enough room in a KE20 strut tower to get any camber adjustment
it's running a tribute livery. It's based on a privateer that received a little support from Toyota. I do have the name of the driver some where. It's running a 2TG with twin Webber's etc. through a Bluebird diff with discs. It's running tonight in the Nissan Night Moves around Heathcote.
This car arrived at work today. Apparently we are sponsoring it. Brought back a lot of memories throwing my KE35 at trees
it's not if it was you need to get in line - behind me 😛
was running 235s on the front of my HZ without power steering. Maybe the younger generations aren't as tough as we were (or maybe smarter) 😉
sorry about the original post. Don't know what happened there. Wouldn't let me edit it either......
Hi all  Trying to source brakes for works '66 KE10 auto display car. All my sources have come up blank for shoes, wheel cylinders and a master cylinder. What sources are people using?
have had the pin in the selector shaft break during an event locking me in 2nd. pulled the shifter and tried to fit a splitpin but dropped it into the box 😞 ended up scrapping that gearbox.
everything will bolt on
3K engine on a Wheel Horse Tractor
coln72 replied to Randy_in_Ohio's topic in KExx Corolla Discussion
cool -
Nice looking KE30 by the way. What are your plans?
Coln72 on here. Guvna everywhere else. To the point where workmates haven't known my real name at times........
Welcome This is going to be weird for me as I get called Guvna all the time at work.......
The old man's old Briggs and Stratton would loose compression every so often. Would pull the gear and smack the exhaust valve a few times to knock the carbon off it. Worked everything.
ditto. Hydros will handle 8000rpm no problems.
This is starting to rival Binky in length of time........ 😉
first set cost me $25 back in the 90's including the aircleaner. I was given the manifold to start the set-up I had on the racer. Basically ask what you want for them and if they sell great.
in the end mine had bump stops cut in half and the rear leaves "curved" the wrong way. Looked good but the only compliance was the sidewalls of the rear tyres.....
