Everything posted by jono1986
Electronic Distributor Internals
I'm not sure that will do it, i might open it up and try and get a soldering iron in there.
Yeah not $120 can get another dizzy cheaper than that....I think.....It's not really a cover, it's two parts one holds the little pcb and the metal bit holds the power transistor to act as a heat sink. So i think the soldered joints have moved but it's been specially built (on the cheap though, most probable anyway)
Hey guys, I was having an intermittent misfire with my new dizzy in and now it's alot worse. Pulled it out and found the plastic cover to the ignitor part was loose and after pushing and what not it ran better but I reckon it needs replacing. I don't know what car it came off, I've pm'd the guy I bought it off but thought some people might know where I can get all new bits. Here's a pic of what I'm talking about: Cheers
Shed Space
Yeah if you have some free time.
Shed Space
Just had a look and there's no crack, and the old caps don't fit the new dizzy....just took it for a drive and it doesn't seem to want to idle after a little bit of driving.
Shed Space
I'll have a look, but it's brand new
Shed Space
Having some issues with it at the moment, something to do with the new dizzy maybe. Seems to be misfiring sometimes, and stalls at idle sometimes....be good for a minute then it will misfire like a bitch.
What Grinds My Gears.
WGMG - Lack of self motivation to work on ones car.....so many idea's....too much cbf factor.
Shed Space
Cheers man, I might of spoken to soon. Might end up scraping it in the end, will see in time.
Lock Your Doors Peeps
Or I know someone that can install alarms systems pretty cheap, alarms that have a reminder beep to lock the doors.......... :wink:
Can U Adjust Steering Column
How long have you had the car? I'm 6'3 and I can get in and out of my 35 with no troubles....
Australia Day Cruise
I did that route in my ke35 and it wasn't in the best condition back then, you should be fine....and there will be people (hopefully everyone) taking it easy and just enjoying the day off and the rolla's. You might want to check that you can do this as it is fire season and inside a national park, some parks don't allow you to have an open flame or what not.
hmmm....how bout this route...except with a different starting point: This post http://www.rollaclub.com/board/topic/44847-cruise/ BUT...I have a list of all turns and straights.....is a good mixture of turns and straights. And if you wanna go further we just add onto it.
What Way Is Easiest To Pull A 4K Out?
When I did the conversion we did it this way twice....damn spigot bearing but it was easy as cause there's only 4 bolts and you can align the gearbox on a bench and whack the whole lot in at once, and cause the gearbox's are fairly light you can just lift it into position with the engine on a hoist and on a bench. I can't really remember if we did this with the autobox or not though, it is much heavier than the manual one so....if yours is auto make sure you either undo the bolts that connect the torque converter to the flex plate or have a oil catch underneath that area while you disconnect it as oil will go everywhere.
Tv Reception
Can you con 75 bucks from somewhere cause that's all a antenna guy will charge you to get a plug in your room, that is the best bet unless of course you can get in the roof and install a proper aerial splitter and run cables yourself. Ummm cbf'd reading the latest replies before i wrote this but hearing the same info twice is always a good sign :happy:
Shed Space
Hey guys, I'll be removing my engine and G.box next weekend but I don't have any storage space. Can anyone give us a little bit of shed space for a little while, unless someone wants to buy them off me I have a thread going for them. Preferably around Cumberland Park area but anywhere is good. Cheers guys any help is well appreciated
Ke30/38 Value Pics Up
Come on man....Coupe wins hands down I reckon, like the wagon but one word....Coupe.....another 2 cents
I don't know how to do the fancy emoticon way but.....This thread is useless without pictures
Event Attendance Discussion
Force of habit, will be doing that for the next couple of months. The main reason I wasn't coming to cruises was that I didn't think my car was up to standard and was a little embarrased by it, but now I realise....I mean come on...it's a 35 coupe. I think alot of members need to realise this and I think the organisation required is already here to do what has been stated as is making dates, routes, posts and what not just need to make more solid meet times and go from there. We have the Australia Day cruise happening this month so that's a start for a state meet. I think also people are from all over the state from victor to salisbury so there's something else to look at.
Hmmm...I should be 5king it up by then so I'll be up for it. I've got a pretty nice route aswell, goes from Hub area to Gumeracha.
Should we relight this fire for 2011 to promote attendance to cruises and what not, maybe start up a monthly cruise?
Eliz Upi
You know there is a topic for this. http://www.rollaclub.com/board/topic/35326-upi-spotted/
Cruise 2/1/11
Definately going to look into suspension and engine upgrade after this cruise....not gonna make a good name for myself if I'm always hanging at the back trying to keep up.
Cruise 2/1/11
Ummm....your saying it was a 10 hour cruise? Where did you guys go after windy point?
