Everything posted by jono1986
Problems With Ke70
Does it cough and splutter after it's heated up a bit? Can you tell us more about when it's doing what it's doing.
4Ac Into Ke35?
Just get one and rebuild it, easy as man
How To: Fix Broken A-pillar Plastics For Ke30-55
Nice thread man, got this problem but looks like it fixed now.
5K Or 7K Engine For My Ke70?
Super Charged 5k.....do it
Classic Toyota Cruize: Sunday November 21.
I would of but 2 problems, i totally was thinking it was next weekend for some stupid reason and my 31 year old leaf springs don't like to corner. been saying this for a while but might have a job by the end of the week so leafs are right at the top of the list.
Ke55 Tail Lights.
You can just unplug it and try, the relay (if even fitted) is underneath that kick panel next to the accelerator pedal. If you have a multi meter check power going into the switch, according to the diagram it could be a white wire or a grey wire or a red/green....this is easier in person.
Ke55 Tail Lights.
ok, so it's either the switch, the relay or the fuse.
Rollaclub.com Suggestion Box
Sorry was there an update for the Instant Messaging system or?
Ke55 Tail Lights.
Do the dash lights work?
How did this go?
- 4Ac Into Ke35?
Ke55 Tail Lights.
Sorry i meant parkers
Regency?
Yes it's a road worthy check, when your car gets defected you have to take it to regency to get the defect taken off, after you've fixed the problem (although you can also get like a lower defect where you just go to a relevant police station). haven't had much experience myself but if you get defected and you fix what you were defected for, they can look at other problems and defect you on other things. Edit. And your car gets defected by a patrol car, like they pull you over for a reason then have a look at your car and defect you based on what they find.
Know Any Small Capacity V8
Is there many of them around?
Ke55 Tail Lights.
Do you have power going to the back of the light? Do you have continuity between the earth of the light and the body? If the globes have been replaced are they double filament or single? Do the rest of the parks work? Do the brake lights work? Ummmm.....
Can you get one of them rover V8's with just a gearbox, or do they all come with the transfer case setup on them?
Matts Swb Pajero
Please find this elusive camera.....want piccies :yes: :yes: :yes: :yes: :yes: :yes:
Speedo Not Worky
Where does the needle sit when the car is sitting still? If it's sitting at 180, take the face of and twist the needle around down to zero.
What? Want Less Power?!
Wasn't taking a swing man. Good luck with it.
Apexi Power Fc
http://www.paulr33.com/powerfc-faq/powerfc-faq.htm#65'>http://www.paulr33.com/powerfc-faq/powerfc-faq.htm#65 http://www.paulr33.com/powerfc-faq/powerfc-faq.htm "Hey guys, I have a Apexi Power fc unfortunately an internal micro-processor that is used to monitor the map sensor is fried. Does anyone know where I can source parts or know of an electronics place that can fix it" I think it would be a specialized part mate, you'd have to get it directly from Apexi aas micro-controller/processors are programmed specifically for the job that they do.
77 3Kc Idle Problem
Damn....normally that's the first thing that's said with problems like that, missed it.
77 3Kc Idle Problem
Did you do the points gap? and is it correct at .45mm (i think) How bout the coil and ballast resistor what condition are they in?
Ummm...have you ever looked under the bonnet of a car....From that reply somehow you've actually wasted the time it took for me to write replies plus this one......
fark....is this for a daily? Just go out and buy a small car that already has good fuel economy and use this car for days you want to use that 3L/km more...... the solar hydrogen idea isn't too bad....what do you put into it? Water...hmmm.... (i'm not upset, just bored)
Unless you set up a home solar hydrogen generation kit, compress it and put it in your car.....
