rian
    1777
    37
Everything posted by rian
  1. Apparently you just turn up and get a one-day license. This is all the info I could find on it: http://calendar.qldraceways.com.au/event_view_popup.php?event_id=4849&ret_link=reader.php?'>http://calendar.qldraceways.com.au/event_view_popup.php?event_id=4849&ret_link=reader.php? And this is the QLD Raceways calander: http://calendar.qldraceways.com.au/
  2. There's one on Sunday, will your car be ready? Let's do it!
  3. Anybody keen on going to one of the General Practice days at QR? It's $120 for a full day and you just need a one-day QR license (if you don't have a motorsport license), helmet and long shirt/pants.
  4. WMMH: New car has air-con
  5. rian
    Rians Ke70
    Thanks dudeface. I'll defs let you know if I'm coming down, or if you come up to QR or whatever give me a shout. I just bought a new daily and don't need to rely on the KE70 to get everywhere now, which means it is actually going to see some track time in the very near future ;)
  6. The only ways to have height adjustable coilovers with a captive spring that I can think of is to use base height adjustable coilovers or helper springs (or tender springs if you want a progressive spring rate). Using a taller spring with the same spring rate will just make you car higher. If you can build the coilover so the spring is captive at the desirable ride height then that would be the way to go, but it's likely you won't get enough droop if you use stiff (over 6kg in a KE**) springs. This is why people use helper springs. If you run a softer spring you can get a reasonable amount of droop while still keeping the spring captive, like stock springs for example.
  7. - Hurricane and Redback make headers - Pretty sure Crow Cams, Tighe Cams, Wade Cams and Camtech all make cams or do cam grinds - Carbs kits are available on ebay etc, or you can use the factory twin carb setup if you can find it - Redline and Lynx make intake manifolds (to suit Webers and maybe Solex? Don't know about SUs and stuff) And this will be helpful: http://www.rollaclub.com/wiki/index.php?title=Tech:Engine/K_Series/How_to_build_a_tough_K_motor
  8. Mine was brown underneath, I wish it was black.
  9. Be there or be square, or just have a square car because that's cool these days.
  10. Thank you very much Hiro.
  11. Do a skid.
  12. lulz.
  13. That's because you're weird. AW11 > SW20 > AE86 > whatever that thing is^
  14. Hey RC, I'm going to look at a 2004 Corolla ZZE122 tomorrow that I might buy and I was wondering if there is any way check if it has any error codes. Does this model have any kind of on-board diagnostics, like OBD2? As I can get an OBD2 scanner easily. Also, if any of you own a ZZE122 Corolla, is there anything in particular that I should look out for when checking out the car? Cheers, Rian.
  15. That spoiler... Hotwires look good though :y:
  16. Are you a wizard?
  17. Do a skid.
  18. Nice repair. The paint on this car looks tops.
  19. rian
    Rians Ke70
    Tharnk you, tharnk you very murch. Note to self: cannot type Elvis impersonation.
  20. undope.
  21. You will be literally rollin' on dubs, that's too cool.
  22. Australia Day is shit.
