Jono.C
    2479
    28
Jono.C last won the day on June 21 2023
Jono.C had the most liked content!
1 Follower
About Jono.C
  • Birthday 12/19/1993
  • Location
    Tasmania
  • Real Name
    Jono
Recent Profile Visitors
32128904 profile views
Jono.C's Achievements
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Posting Machine Rare
  • Week One Done Rare
Recent Badges
81
  1. Yeah the actual ball joints them selves although different size / taper are same size where they press into the arm
  2. From memory the ball joints will interchange Theyre not really a street LCA. There’s no benefit to them over the factory ones unless you’re just trying to gain wank factor
  3. Funny how many people don’t seem to know this forum exists Plenty of people on the Facebook group, usually with the same questions getting asked.. The same questions as 10 years ago on here with all the answers. I still come back here from time to time to see what’s happening but it’s a shame it’s not like it was years ago. I have much of the FAQ and many other threads saved and printed for the day the forum no longer exists, but I’m glad it still does.
  4. Ke20 are the longest of the Corolla lcas From memory ke20 is approx 325mm while ke30 is 310mm Unless they have a ton of adjustment they won’t be long enough and you’ll end up with positive camber. What’s the reason for wanting longer Lca’s? Just for camber?
  5. Been a long time since i was on here. A lot has happened but still a lot to go! Car went off and had rust in engine bay repaired (was very little for it's age) and the engine bay has been resprayed factory colour. Pretty in love with the colour 7k and t50 are in and running and currently fitting all new balljoints, tie rods, control arms bushings and idler + pitman arms and having all the front end done in 2k black. Car will soon be heading back to have the rest of the bodywork done and painted.
  6. It did, I came across it on gumtree a couple months back looking exactly the same as i sold it. I ended up having both this, and my ke18 and about 5 other cars and some just had to go.. I removed most of the best bits and kept them for my ke18 and sold the sprinter to a guy down here just after my last update in this thread, then never saw it again until the Gumtree ad
  7. What are you thinking diff wise? Escort or something larger?
  8. Would have a pair in Tasmania
  9. I bought a distributor cap off a km36 liteace with a 5k engine. Distributor cap is same size but runs conventional 4k style plug leads etc
  10. Whats the reason for using the 4k distributor? The 7k one is electronic and a better unit
  11. I built coilovers for my ke10 using golf gti shocks. i removed about 90mm from the strut tube as i'm 4" lower than stock and didn't want to run any spacers under the shock etc. They will work fine but you'll need to get your springs etc first and lay it all out to figure out what size spacers you'll need under the shocks or how much to cut out the strut
  12. Where did you manage to find the lower arm bushes!?
  13. Pretty common to swap to a solid billet style one in silvias etc for more direct steering feel. Theyre available pretty cheap for those.. could be worth messaging a seller to get pcd and see if one would work
  14. I have one in the shed in Australia, 20 + post
  15. Both will fit. Keep tyre size to a 185 or 195 and shouldnt have an issue
