January 7, 200719 yr comment_158266 I THINK daisy ran an 18.2 with the weber the Cricket ran a 16.9 Report
January 7, 200719 yr comment_158296 My ke30 V6 rolladore has done a 14.6 @ 151kmh so far, Currently top speed is 151kmh as a holden V6 has a rev limit at 5800rpm Report
January 7, 200719 yr comment_158306 My rolla does a 16.4 @ 130kmh and the Mazda has done 14.3 @ 150kmh :) Report
January 7, 200719 yr comment_158312 in my datto 1600 i did a 1.17 around symmons plains and a 1.11 around baskerville Report
January 7, 200719 yr comment_158317 Just like to ad that my brother's (Ricky Johns) Lj Torana ran the 12.20 on 15" 205's with 60ft of wheelspin, He did not stall up, just tried to drive it off the start line fast (the slowest time that night was his 1st run of a 14.72 @ 103mph due to major wheelspin on the line), He only has a mild engine package as he wanted to keep it street drivable (not sure of the exact HP but it is around 400), It has been off the road for the last few months getting tubbed to run the 265's and having the rear suspension moved, Also having the minispool changed (from memory it has gone from a 23 to a 32) and upgraded the carby to a holley 750 Double Pumper, It will run in the high 11's but I'm hoping it will go in the low 11's. I will post before and after pics of it in the next couple of weeks but not in this topic. Just put a vid of his up, His is the 2nd car the other is his mates VH: Updated the vid so and the link didnt work, all fixed now. Edited January 7, 200719 yr by Trev Report
January 8, 200719 yr comment_158415 how do people rate the G-tech gear? Meh they seem to give a fairly accurate time so test it and then let me know and i will post it up :) Report
January 8, 200719 yr comment_158423 If you have Rally times on a well known coarse i'd like to post them up aswell. Report
January 8, 200719 yr comment_158428 I have done a 1min 34.94sec around Hidden Valley Raceway. I plan on going to the drags first chance I get this year, so I'll post a time for that when I've got it. The Hidden Valley lap time will also drop this year. :) Report
January 8, 200719 yr comment_158434 how do people rate the G-tech gear? G- tech seems to be very accurate, the only think that can throw it is bumps in the road, even minor ones so you need a perfect road, ther than that it is spot on. Report
January 9, 200719 yr comment_158603 I disagree with G-Techs being allowed. If you can't be bothered to go to the track and do it in a safe and proper manner why should we be seen to encourage or promote illegal activity's on the street? (Obviously you're doing it on the street if you're G-Teching otherwise you'd just go to the track and do it properly) Report
January 9, 200719 yr comment_158604 Rules amended, This forum does NOT encourage illegal activity. Report
January 10, 200719 yr comment_158688 Rules amended, This forum does NOT encourage illegal activity. Thats a very good rule to address BUT (Here we go :) ) what if the time recorded was done at somewhere like the main straight at qld raceway or another track and they havnt been bothered to go to the drags to test it. Report
January 10, 200719 yr comment_158704 Good Point but you can't prove if they did it on the street or at the track, Atleast there are slips from the drags. Edited January 10, 200719 yr by too quick Report
