Today while Matt is away at the rally, I got a late start in on fitting the brake booster. Now I know it is going to bolt in properly it is time for a few coats of undercoat then it can be painted..
That funny bell shaped thing where the old clutch cable used to come out - why didn't you just cut the whole thing off? Instead of nibbling a bit of it away to clear the clutch master?
There are multiple reasons
(1) In case for some weird reason he ever wants to go back to a cable clutch.
(2) Less work involved to die grind a piece off the old cable clutch bell.
(3) Engine bay is already painted, Don't want to make a mess of it if I can avoid it.
that "bell" in my ke20 came of with two firm strikes with a hammer - and absolutely no mess at all. Whats more, its intact and could easily be put back on if i ever need to go back...which i won't.
Looking good though!
WOW that is one hell of an effort! are you guys using it as a show car or what ? hmmm id never take this out past the garage door :P but if you ever sell it in the same kinda nick id be very interested ! Gr8 work keep it up.
