September 11, 200818 yr Author comment_274149 Yes, Except its from the extractors back, as it has no cat atm. So Loud. Report
September 11, 200818 yr comment_274197 keep the limo, you will learn to love it. theres a company that refurbishes seat belts if you want i can try dig up there details. you send them belts, the replace the belt part with new material in an array of colours you can choose from, and they service the retractors and everything so theyre good as new when you get them back. Report
September 11, 200818 yr comment_274200 all I'm gonna say is you must be one fussy bastard love your work! Report
September 13, 200818 yr comment_274613 Keep the LSD. Open centers suck, and with the extra power you'll certainly not want an open center or you'll spend half your time single spinning and not going anywhere in a hurry. Report
September 13, 200818 yr comment_274615 Keep the LSD. Open centers suck, and with the extra power you'll certainly not want an open center or you'll spend half your time single spinning and not going anywhere in a hurry. Ha Fook it took him 5 years to get this far, Do you think he is in a hurry :) Report
September 13, 200818 yr comment_274624 depends how you drive. i've an open centre with my ke20 with 130rwkw: perhaps a little bit more than you'll get with a stock NA bigport. Unless you want to push it hard around corners or dump it off the line an open centre will be fine. If you want to be dangerous and pretend your fangio around blind corners then perhaps get a dedicated track car instead and you won't kill anyone crossing the street (this isn't directed at anyone except there are a few local dickheads taking a corner near me at warp speed). What Matt's got is a super neat cruiser with a bit more balls than standard. Put the open centre on and look after it. Edited September 13, 200818 yr by Jono Report
September 13, 200818 yr comment_274626 what tyres is it on at the moment? i think with some good tyres it might help... what issues are you having with the limo anyway matt? skipping around corners its so tight? or just sliding when your not expecting it too/ Report
September 13, 200818 yr comment_274634 I recon it just needs a raping to loosen her up a tad :) Report
September 16, 200818 yr comment_275265 or just leave the lsd as is, it gets worn out by the time you've got used to it if it's really tight you can always replace a shim or 2, or just get some decent tires on it, I vote for A048 :y: Edited September 16, 200818 yr by David Report
September 16, 200818 yr comment_275280 Just give it the old drive in figure 8's for 20 mins like you have to with a KAAZ centre. Report
September 16, 200818 yr comment_275406 Ill swap you my standard AE71 diff and ill pay the postage :y: Its ok no need to thank me i know I'm doing you a big favour.:y: Report
