Everything posted by Jordan
My Caa22 (ca18det Powered Ta22)
Update, there have been issues getting the stock ECU reflashed, so I've bitten the bullet and bought an Autronic SCM with all the trimmings. basically an SM4 minus the speed sensor. Also have a new set of flares that'll allow me to run 225/55R15's with no problems on 15x8" -9J rims. Cheers jordan P.S: I'm now working as a Ventilation Engineer at Broken Hill, so there should be some serious updates to this thread shortly.
Nissan Ca18/sr20 (det) Into Ke70..??
as to the question about gearbox mount. Simply dummy up the gearbox where it'll eventually sit and either: a) Modify the standard mount b) Make a new one in eithe case you'll need a welder, and deffinitly an angle grinder or 14" drop saw. Cheers Jordan
Davros' Ke10 4age Project
if you put those wheels on I'm personally going to come to Queensland and you know I've got your address, put your car up on bricks and toss them into the sea. It's a KE10 dude, run 13's or 14's absolute max, crazy dish (old school mini style.) Higher profile tyres (they'll give a much better ride,) and handle better as well. Something like a 13x7" +5 kidney mag in gloss charcoal would look awesome. Cheers Jordan
Cruise, Saturday The 12th Of April
The answer is not yet. Leave to go back home around 5 this afternoon. Cheers Jordan
Whee'd everybody get to? :) The cruise for the 4 that made it the whole journey was a genuine blast through the hills, finished off with a beer and a few laughs at the Norton Summit Hotel. Hope to see you all next time Jordan
Cheers for the overwhelming interest. Should be a good night to catch up and have a yarn. See you all just after 7 Jordan
I'll have a spare seat, so if anyone wants a ride. note: must have valid reason why they cannot bring their own car :hmm: Fuel's too expencive doen't count :dance: Catch you all Saturday evening. jordan
Hello All, Back in Adelaide this weekend from broken hill, so it's cruise time (as good an excuse as any.) Meet place will be the Foodland carpark on Magill Rd, just before the Towr Hotel as you're headding out of town. Meet there after 7:00pm for an 8:00pm departure time. The route should take about 1hour 30 minutes. Catch you there Jordan
Ca18 Into Ke11??
$2000 for a complete swap, dam that's uber cheap. I bearly got away for under $3000 upgrading the turbo on mine. Cheers Jordna
Thank you for your kind words, it's been a long road to where it is at the moment. The RB20 AFM will only give usable information on airflow up to about ~230RWkW, and I'd be very happy to see it make 220RWkW. If for some reason that isn't enough, I can always get larger injectors and a standalone ECU like a Wolf 5 or Autronic, as the turbo and everything else are plenty large enough. As I mentioned in the first post I'm moving to broken hill in the morning (Dam 6:30am flight,) but once I can organize to have it tuned (likely to be late next week) I'll have they dyno sheet posted up. I've always planed for this car to basically become a weekend racer, hill sprints, super sprints, regularity, open track days, motorkhana, etc... so hopefully it'll be up to the task. Cheers Jordan
In January 2007 I purchased my 3rd classic Celica, a CA18DET powered TA22 from Queensland, and had it thrown on a truck and delivered to SA. When I bought the car it had a full interior, fairly clean CA18DET installation, running a T28, 13x7" kidney mags, king springs and a god awful SAAS steering wheel. It made 150RWkW @8000RPM on 10PSi. Since then much has changed: (in no particular order) Engine Modifications Forged Pistons, balanced bottom end, metal head gasket and re-con'd head BlackStone Aluminium radiator (see mid 80's V6 Volvo sedan,) using Magna TM radiator hoses and Volvo header tank Late model Camery brake master cylinder 17x12x3" front mount intercooler with 3" mandural piping Catch can, made from 3" pipe, with 2 internal baffles along with a sump return and breather Bosch 910 pressure pump, fed from a surge 2L tank fed by one of those noisy electric low pressure fuel pumps. Bosch external coils with 8mm Topgun leads 550cc injectors Garrett GT2876R 48trim roller bearing turbocharger with 0.64 T2 rear housing Earl's Speedflow fitting used for the turbocharger Bashed in strut tower and ground down oil filler cap to fit said turbocharger Ebay High mount Stainless steel exhaust manifold with T2 flange welded on New custom made 3" straight through exhaust with side pipe Body modifications, inc electrical 15x8" Performance challenger wheels (has also been seen with various other 14x6" and 14x7" rims) Sheet metal rivited over the back seat and rear parcel shelf Battery moved to the boot Completely new electrical body loom installed, after the old one stopped working Washer bottle relocated to the passenger foot well Boost gauge installed in the drivers side air vent Fully stripped interior of tar Sparco fixed back bucket seat installed New wiper motor RB20DET AFM wired in Guards rolled (badly but at least the 15x8" -9 rims no longer scrub) AE82 Twincam steering wheel Driveline Ogura Racing Clutch (ORC) Twin Plate Ceramic clutch (includes a billet steel flywheel) New Diff, as the old one spat and axle Change from 4:11 to 3.9 diff ratio, along with new bearings Locked Diff centre Suspesion and Brakes Front struts changed to RT132 corona items with Sumitomo twin spot front brakes Bushing kit After market front and rear sway bars installed Koni rear dampers Cosmetic Replaced the rear light surrounds (which had been painted green) with original ones that still have the chrome New Grill (modified to fit the new cooler) with early style LT badge front and rear Autobahn parts used: 3"-4" silicone reducer Fabrication of the exhaust, inter cooler piping and catch can were all done by myself and Andrew of Premium Safes (where I've been working,) Engine machining has been done by Chris Milton Engine Developments, all other work has been done by myself with the help of a few friends. and with the old grill and 14x6" wheels The car will be going in to be tuned and dynoed next week at this stage, as I'm moving to Broken Hill so some things just have to wait. Shortly I'll be installing my Land Cruiser front brakes, seam rivet or welding the chassis, stiffer springs, dampers and a large order from T3 (techno toy tuning) is on the cards in the next few months. Cheers Jordan[
Toyoshow2008
Adam, you're welcome to enter on the day, and just because it's got a 202 in it doesn't mean it can't enter. It's still a KE20. Personally, I've been wanting to see your car for a while so I'd love for you to bring it down. Cheers JOrdan
My 86 Project
if you haven't got linkages sorted yet, get hold of roger form here or Toymods, he made the linkages for my carbie 4AGE setup. It's very good and super easy to install. Looking Good Jordan
- Cruise Soon???
Toyoshow2008
I'm there, but will likely miss the cruise due to fear of defect (cops don't look too kindly upon straight out side pipes, big high mount turbos and single seaters,) unless I can get a trade plate for the evening. If it is able to be tune by the end of the week it'll be at the dyno but it will 100% be at the show 'n' shine regardless. Cheers Jordan
2nd Annual Rollaclub Great Ocean Rd Cruise
it has it's moments $$ :) Jordan
1: I'm moving to Broken Hill next Monday, and have to get things sorted 2: The CAA22 is still in bits and has to be back together by Wednesday evening so it can be tuned :) Cheers Jordan
Ae71 Track Car Project
it's easier to use a medium sized screw driver. also don't heat the tar, it makes it go all sticky, if anything get dry ice which makes it chip off easily as the cold breaks the bond between the metal and tar. Jordan
Sa Transportation Laws
only if there is a sign saying so. Unfortunately you'll only find these signs in Canberra. Jordan
would love to come but can't, hope you all have a great time. Jordan
Cruise Soon???
there is of course the the Toyoshow cruise which I hope you're all attending. Jordan
to change the colour or engine number is simply a form, and required no cost. Only hassle is having to wait in the line jordan
Trev's Ae71 Panelvan N/a Bigport
do you have any sound bites (AKA: sound recordings or videos) of this motor when you're giving it a hiding? Cheers Jordan
Finally bothered to read the first post :D If you're going EFI and supercharged and a rebuild, sell this good 2TG for good scratch and then buy a blown one for peanuts and rebuild that. Hell take a trip to U-Pull-it and grab yourself a 3T crank (there are 2 TE72's at the south yard) and a set of 3T pistons to get 1770cc (or buy 89mm wiseco's to get 2L) and do it properly. Cheers Jordan P.S: why not go turbo since you're going EFI?
13b Rotary Conversion - Ke70!!
Some time in the 70's Jordan
