You need to get an oxygen sniffer in the exhaust pipe & read what the mix ratio's are. As you increase the RPM, you really need to map out whats going on.
For turning a car like this, unless you have a known working formula you can program in as a base map, Trying to get a proper tune without the use of a dyno is going to be long,
hit n miss & possibly quite damaging to your motor. Be.. careful now. Id image your well aware of Lean & Rich dangers lol.
Just by looking at that curve of fuel vs Engine RPM, it looks like its going to be Lean, Flat line then Rich haha. Id be interested to see what it is in reality.
Besides, if your getting a Supercharger on the thing, Why.. try to tune the thing as it is atm, only having to do it again later, differently ? unless your running a 2nd map with a different tune i suppose
for supercharger mode?
*shrugs*
Good luck lol.
Oh, and throttle body adjustments - unless you re-designing the wheel, id be incline to get the manual out and set the thing up as it was from factory, simply for the fact of knowing when
the car should be at idol, your going to have a known amount of air flow through the bypass setup. Along with the ability to still retain the cold idol bump up / heating circuit in the TB.
Well, that just what i think anyway : )
