Everything posted by rian
Sup Rollaclub? Let's Have A Chat.
It could be called the "rollaclub ride or die cruise", because if no one went rollaclub would die.
The .gif Thread.
^ Dude why are you posting funny shit? I only come here to watch MMA.
Rians Ke70
This is what it will look like when I go to the track, plus Kamei front spoiler. Also I now have 4 Hartge wheels! AWWW YEAHHH (shitty phone pictures sorry)
The .gif Thread.
That was wild!
What Grinds My Gears.
Take toilet paper with you?
What Makes You Happy Thread
E10s collect respect
Blaike's Blacktop Ke70
Yeah man! A cheap 175/60 on an expensive 8.5" wheel is the best way to make your car worse at everything cars are designed to do. A true anti-performance mod! Sounds bawwwwwws.
- Mitsubishi Alternator On A 4K
Repco will get one for you ;)- Luk3333's 1982 Ke70
Your calipers have "2014" stamped on them, they are definitely ADM. Unless you got new calipers since this photo: They may have sent you the wrong pads??- Moe's Ae92 Daily
Are you planning on changing the suspension in this car?- Sr20 Into 84 Ke70??
Things you require to do this conversion: - These mounts: http://www.rollaclub.com/board/topic/64554-sr20-mounting-kits-now-available-ke30-ke70-ae71-ae86/ - 10 thousand dollars - standard KE70 body - upgraded everything else, like every single driveline/suspension/braking/fuel/engine component, there's not even any point listing them because there are too many.- Mig Gas (Argon)
BOC at Campbelfield?- Ke70 Wags Build
Your dash is looking super sweet. That's a good solution to covering a cracked dash or just as an alternative to a dash mat :y: With the brake lights, the brake light switch is probably stuck in the 'on' position because it needs adjusting. You should be able to adjust it with a spanner? Also, I'm not sure if it will matter but I'm pretty sure the ECU is made of aluminium because it's a good thermal conductor, wrapping it in the carbon stuff might trap the heat it?? I've never felt an ECU when the car is running but apparently they get hot. Though it does look good.- Sigma Lca's Ball Joints????
^ That's what I meant, I just didn't explain it very well. They "fit", but the taper's between the Sigma balljoint and the Toyota steering arm don't match.- Peanut Bait
^ That's what I was thinking, it's like a snowboard on wheels.- Sigma Lca's Ball Joints????
Also, the Sigma ball joint has the wrong taper and doesn't fit the Toyota steering arm (not the slightest bit surprising, considering it's made by a different company). Anyway, you get ~ 4˚ negative camber from Sigma control arms, which is a lot. Unless you set up the suspension to actually make use of that camber you will probably lose cornering and braking ability.- What Grinds My Gears.
WGMG: This car, it's everything that annoys me about KE70s.- Peanut Bait
What's that thing in your boot? Is that one of those things people hold glass with? Did you know you can buy end caps to suit KE70 chrome bars on ebay?- Rians Ke70
AWWWWWWWYEAHHHH. Dude if we lived closer together I would come help out. Actually I would consider driving there just to work on a GZE, if you get stuck on a 2-person job or something just holla. Cheers big ears.- Rians Ke70
We'll have to get them together at some point, hopefully on the track!- Rians Ke70
- Project "rust Bucket" Is Here.
^- Project "rust Bucket" Is Here.
You should call this the Bogrolla.- Ke70 Wags Build
What's the go with the AE82 master cylinder? Is it a different size to the normal KE70 master? - Mitsubishi Alternator On A 4K
