rian
Everything posted by rian
  1. Can get new ones from Autobahn/Repco/Supercheap. They're about $90 from memory. Is it just the gasket/insulator that is leaking? You can probably get that individual part from Toyota: http://www.toyodiy.c...AEMRU_2301.html
  2. How do you know it's not the plugs or leads? You should also try replacing the capacitor.
  3. For Zowie: http://youtu.be/vxOqruk_8t4
  4. The slave cylinder pushes the clutch fork towards the rear of the car. If the rubber part (where the pushrod goes) of your slave cylinder is facing the front of the car then you have the wrong slave cylinder, you probably need a slave cylinder for a TA22 Celica/T18 or something like that.
  5. Which T50 are you using, is it a T-series T50 or an A-series T50? T-series T50s have the slave cylinder on the drivers side of the gearbox, and most (excluding JDM) A-series T50s have the slave cylinder on the passenger side. Maybe you have the wrong slave cylinder for your gearbox? Also you should be able to get that rod from Toyota, or you can just go to the wreckers and pull it from and Corolla newer than 1985. Edit: here is a link to that image http://www.toyodiy.com/parts/p_G_1984_TOYOTA_COROLLA_AE71R-EEMNCQ_3105.html
  6. I am a genius.
  7. The part that bolts to the transmission is called the slave cylinder. Are you using a T50 gearbox? There should be a little pushrod (part 31473 in the image below) that connects the slave cylinder and the clutch fork.
  8. Put new fuel in it.
  9. OMG BOLT-ON PARTS MAKE ME GO FASTER
  10. Yeah I could probably get a small one, but I figure if I'm going to get one I may as well get one that I can paint with. And the small ones are all direct drive and have alloy heads, plus crappy rated duty cycles and a small tank would be a pain in the butt. I don't necessarily want a big one, I just don't want a shit one. 50L and belt drive would be good.
  11. Especially when you want a good one. I've been searching for a second hand belt drive one for a while now. I'm considering getting one of the Stanley ones from work, 50ltr tank, 200LPM, cast iron head, belt drive etc. About as big as they get without being 3 phase, but so expensive :(
  12. Someone sell me a compressor.
  13. That's weird that that person filmed themselves running on a treadmill...
  14. Those are excellent wheels.
  15. ^Yeah I don't buy shit unless I can pick it up or it's from a legit business/reputable member. I got stung a couple of times by douchebags who didn't post things I had payed for (was partly my fault for being too trusting), so I'm not buying anything that needs to be posted anymore. This is probably the greater part of the modified car scene. I'm actually ashamed to tell people I'm in to modifying cars because they would probably think I'm another dickhead bogan who likes to rip skids and run over letterboxes in people's front yards.
  16. rian replied to KO 10's topic in Rollaclub Rides
    Looks awesome.
  17. ^ agreed, Sauron is a megadouche.
  18. KE70s are gay, Falcons are where it's at! Besides, isn't that why Ford designed them?
  19. ^get happy, do a skid in your Falcon.
  20. KE70_Chassis_Electrical_System.pdf
  21. how much ground clearance do you have? Looks super low.
  22. http://youtu.be/LF0IhyAasWw
