September 22, 201313 yr comment_667611 starting to suspect no one gives a rats? I do, this build is great. Those carbs look awesome. Edited September 22, 201313 yr by rian Report
September 22, 201313 yr Author comment_667614 Thanks for the kind words guys! ,theres light at the end of the tunnel, fireup in two weeks then its video time.... Report
September 22, 201313 yr comment_667617 This build is really good, thanks for the time and effort put into the thread. I have had a real kick in reading it. It is great to see a father and son build that will be seen to the end. I'm hoping that I am also able to share a simlar build with my son in the near future. Thanks again guys. Report
September 23, 201313 yr comment_667624 I'm following every post, just don't comment. Keep at it you're motivting me to get my ke10 build started! Report
September 23, 201313 yr comment_667650 3mm oversize FIAT intake valves, Any dramas fitting them?? Same guides? Same length and colletts? Is it a Fiat seat machined into the K head? That would be quite a performance upgrade just by itself. Nice job on the carbs, that one pictured was pretty bad. Report
September 23, 201313 yr Author comment_667657 Hey guys thank you for your positive replies, ill try and fill you all in as best i can from what the cyl head guru told me ok here we go.... Original valves were too thin for our high rpm, and also a double groove collet and retainer setup, so the ALFA and FIAT valves were the go for , a budget replacement, they are all stainless single groove style valves with collets and titanium retainers(ooooh) to suit, single groove simply to stop tearing the tip off the valve due to so much lift on the stick.As far as seats they were replaced and custom multi angle cut to suit, exhaust valves were also seriously machined to gain the correct height at the retainer. Funnily enough the crow double springs i supplied were 10 pounds less seat pressure than stock 4kc single !!! at around 60/ 65pounds , the LANCIA ones are 80 pounds and quite a bit thicker on the inner spring than anything ive ever seen in a 4 cyl, hence the dunnydoor stem seals, i ported the lot myself over about twelve hours, with a cheap ozito dremel and carbide burr tips and anything else i could get my hands on lol as ive mentioned so many times if a bit of iingenuity, and effort is put in the final result is more satisfying than simply throwing a blank cheque at a shop and ending up with something you may well have been able to do yourself , now lets hope like hell i don't kill it..... Report
October 2, 201313 yr comment_668258 i read every new post, i just can't be bothered typing stuff half the time haha, looking good mate, head and carbs look sick!! so hanging to see a vid when its running :P Report
October 4, 201313 yr Author comment_668436 Kick off tomorow gettin bits cleaned and ready to rock!.... Report
October 5, 201313 yr comment_668520 Holy crap that looks ridiculously awesome, keep up the great work. Report
