camerondownunder88
Senior Member
    1683
Everything posted by camerondownunder88
  1. Hi, Was going to replace my KE15 glove box the other day with a new one I had for it. Went to remove the original KE15 one and noticed this: The elastic mount int eh top. Looks like it has been there since new. Can anyone confirm if it was and if they are original what went there? As my other original box has no elastic in it at all. Cameron
  2. ^^ Those kits look good. Another way is talk to Jason on RC here he has a 4agze with SC14 running waste spark system and coil packs if i remember right he knows that way to. And he runs a megga squirt ECU. Prob easiest route honestly. Cameron
  3. Hi, Taz if your still having troubles try a no load test on the starter. reduction starters no load should pull less than 90 amps at 11.5 volts. I have a how to on rebuilding this starter from Toyota if you need it. Could be a faulty starter as if you have a big batterya dn good starter no reason motor wont crank at 250RPM so you get a pulse. Cameron
  4. ^^ mmm thats a real server. Are we limited to size on this server in Terra bites or what? Also looks like I got some up dates to do now pics can go up..lol Cameron
  5. haha low speed can still hurt your self..lol also is the skid pan privately owned? And is there any straight sections on it and how long and is it a wide track kinda area? Just curious...........
  6. id be keen. Does driver need a helmet and that etc?
  7. there is all ready a massive ass thread on this... Umm search it should turn up also if your movie isnt in the list add it. There are heaps but in music film clips I have spotted
  8. I might be attending..................................so add me Teddy man BUT The Hot Lies are playing in city that night and can't beat a good concert so mmm ill have to let you know pending ticket prices for my show..LOL Also how many people will rock up in TRD clothing..LOL always happens..LOL Cameron
  9. Do you have access to a metal lathe? I have a custom made dizzy for a 4K at home here that has a EFI sensor on it for TBI injection setup for a 4K so ECU and run dizzy with fuel. VERY easy to do just need a good measuring device draw up idea and turn it up. If you want I can get pics of mine. Pretty much if you know what your doing don't see why not you can't fab one up in a day. Mine was ECU advance but no mechanical on it But to add that wouldnt be hard either Cameron
  10. Sorry to hijack but there was a car that automatically locks doors at speed....Where can I get details on the mechanism that does this? If you have answer just PM me or start newie... Also 3M 2000GT version was it a stock 3M or spec'ed up? Cameron
  11. Hi, Part number is in my ride thread below: http://www.rollaclub.com/board/index.php?s...12854&st=15 Go to page two I have pictures of it. But I got it at walkers A1 parts shop in Ipswich he has them on the shelf. In ACL cataloge it is under 2K motor gasket. Now if your good you will find one with a water cooled manifold hole in it. I have looked now since I got the car don't exist now even K-B motor for a KE15/17 is listed as the one I got no water hole. But I happened to run into a guy once that had an original KE15 asbestos gasket with water hole he gave to me so there out there but BLOODY hard to get your hands on. And car shops will argue all day long saying they don't exist the water hole ones well they do I have shown them pics but ACL has nothing or other makers so if you need one fast get the one I have in my ride thread was sub $10 I think and well made. Is for big port but so on a small port head wont line up and they also seal 100% better then divided ones when running extractors. Cameron
  12. Looks like an early 3K BUT has a 4K styled rocker cover with screw in cap SO could be a 4K runnign stock early dizzy normally found on 3K's. But for certain I can say has a red catch can, choke cable looks like it isn't in original holder spot, runs a K powered van intake on it (put a pod filter on :( ) and has a missing aircon belt and is a flat top piston model. The K letter will be on the block to the left of the dizzy if your looking towards the motor with it slanting away from you. Cameron
  13. ^^ Interested in the light setups. Are the just on ones like high beam all the time or like low beam all the time? Cameron
  14. Id rather not buy more as well I got like 7 of these bad boys all test and work at set temp sitting in shed just need a clean so id rather save my moolah..lol
  15. Can you tell me the acid that is in it? I got access to a LOT of acids. And id rather not accidentally dissolve them..LOL Also I'm just worried the grit blaster will damage the valves surface leaking water etc so it wont do its job properly. But I have been told acetic acid (aka vinegar) will clean them up well. Is this true? Cameron
  16. Hi, Well doing up my KE15 cooling system and I want to do it properly so I can make a WIKI article on it. So one part I want to do is cleaning the thermostat. Now these are all tested and work. But are covered in crap :wink: What is the best way to quickly clean them? can I grit blast them safely? Pic below of the mess they are. Cheers Cameron
  17. MMM I like sump pics...Looks stock no mods..lol
  18. ^^ depends on plane little to LOADS for landing. ALso THAT is what I call a flexi take off. I think the el-capitano forgot to carry the 1 in his calculation for flexi take off as man he is right ont he piano keys..lol Cameron
  19. Hi, In all my books On K motors I even have the 5k ENGINE MANUAL they all crank at 250RPM. Upgraded your main power cables yet? The ones I mean are batt to alt to starter and earths? I got 4 gauge cable in KE30 did up grade my self HUGE improvement so try that. No load amp draw from a KEXX starter is 55amps so try a no load test also. Will show if starter is dying. Also sensor position for ECU. Is it close aligned right to pick up the ignition pulse? And is 200 the lowest ECU will do? As if sensor is good and starter loom fixed can't see why a normal starter wont kick it. Cameorn
  20. lack of funds..lol my first goal KE15 on road. second collect pannels respray white original colour slowly. Then one day when red take those panels in all fresh and car and get it original white again. Just time cash etc. Also once new a person who had oin striping on his KE20 NEAT I mean you had to see it to get the effect his was a nice blue with pin stripes white strips on it LOOKED HOT and red ones on dash really defines the cars lines and gives it eht old school look I think it would also suit a KE30/55 Cameron
  21. ^^ Your new car will be white :yes: mmm trouble in Reds Chateu'..lol Well I suppose you did have a blue car once before.. Go green. But white will also be good jsut no black bonnet. OR..... Kinda do a rat rod look BUT it wont be a rat rod. Matt Black all over red pin stripes to complement the chrome strips and then some pin striping around the gauges etc that will make it look the part with white walls. And then some chrome metal hub caps. Cameron
  22. TE35 that car is :yes: I think the green one is best. That is my option but at end of day you have to drive the car. So don't go pink..lol Cameron
  23. The band "The Used" in the song "Taste of Ink" is a TE7X wagon by the looks of it. Also the living end use a KE70 ina film clip and there was another film clip I though of but can't remember it now..lol Cameron
  24. John Light years ahead of you mate. I got 3 TA22 celica adjusters sitting on my desk. One is anodized to :jamie: Also I stole your adjuster when the car wasn't yours so :P And Trevs mate still has it so mm I don't actually have that one..LOL Cameron
  25. ^^^ what don't you know man your clued up on SO many issues. I mean OK this isnt really an issue lots of bands get made up paid and then told to piss of these days. But mmm good that you noticed with this band. Also crap pest COVER ever. But I listen to pink floyd for pretty much the guitar parts so only PINK Floyd can do them as good as anyone else so I prefer the originals. Cameron
