Everything posted by coln72
Ke35 Taillights For Ke55
You would need to change the entire rear panel to the ke35 panel. Lots of work.
- Blue Thing: The Daily / Motorkhana Hack (Now Efi)
- Corolla Aisan Carbs
Upgrade Front Suspension Ke 30 Any Ideas
drain oil from struts and refill with thicker oil measure the internal and external diameter of the coils and head of to the wreckers and find something from a bigger car that is similar. ex. I used cut down HZ Kingswood V8 springs in my KE20 struts.
- Victorian Motorkhana Championship 2014
5K Pushrods
Put the hydraulics back in and you won't have a problem.
Ke20 Rear Tyre Width
Squeezed 205's under one
Random Photo Thread
I could of :(
What To Buy?, What To Look Out For? How Much To Pay?
If I had a choice, I'd look for a coupe/hardtop. Personally, I'd also try to go earlier rather than later. Less pollution gear and usually lighter. Look for rust in the lower parts of the body (guards, sills, rear quarters), around the battery, the firewall, roof gutters and under the fuel cap. I'm sure others will add other areas to look at. Mechanically, k series engines are usually good unless they are not maintained. If you are looking into a conversion, anything if possible but may not be able to be registered. Cost, how much is the car worth to you?
What Grinds My Gears.
Shitting and spewing at the same time. Gastro sucks balls.....
Then do as I do, don't go on Facebook....
Ae101 Khanacross Project
Dunno about your local regs but it would be a good idea to put the battery in a battery box if your gonna leave it there
