Everything posted by coln72
Automatic Aluminium Radiator
Strange the standard radiator isn't up to the job. Used to tow a camper trailer in the middle of summer with my KE35 without overheating problems. That was with a high comp 5k. Before lashing out on the aluminium radiator, I'd be double checking everything in the cooling system to make sure it is top notch and fitting a thermo fan as well.
2015 Victorian Motorkhana Championship
Well played :yes:
5K Hydaulic Cam Suggestions
Dunno. Got to remember that most of my running was being done with the wheels spinning, so maybe the engine wasn't being loaded up and could spin quicker. We set our timing about 12 btdc and used 2 x single carbs as the had bigger throats than the proper 3kb carbs. IMO a 5k should rev harder than a 4k as it has a better bore to stroke ratio. Also, the exact specs of my cam are a guess. It was re ground to a Wade 169 grind but it might of been different.
AMC doesnt count for VMC points, its just a nice bonus to have it in Vic again. If you do the AMC, you'll have to try and knock off my best result of fourth in class.... Luke there is a challenge for you to prove FWD is quicker :P
Nice to be remembered Used to go to 7500 rpm and over (shift light was set at 7500 rpm) during motorkhanas. This was with a 5k running a 169 grind Wade cam, stock valve train, twin aisan carbs, exhaust and a few other things ;) Also ran an electric fan and fuel pump to reduce drag on the motor. can't remember the exact specs as it was over 10 years ago that the cam was fitted, but a quick search gives around 280 degrees duration and .405" lift. Probably not the best vid to show the revs but
Pics And Vids (*e7* Only)
don't have the pic, but a KE70 features in the 2015 R&J Batteries calander
AMC in Bendigo. Just down the road :) Going to have to pencil that one on the calander
- Victorian Motorkhana Championship 2014
Destroking A K Engine
8000 was seen on occasion, but that's where the tachometer stopped....
Best Way To Lower My Ke55 ?
Wouldn't want to be arguing that to the insurance company in the event of an accident. Or in a court of law if there is a fatality......
Chopped spring = illegal That said, I ran them for years with out an issue. Best bet would be to obtain some brand name lowered coils for the front with heavier strut inserts and to get your rear leaves reset with some decent rear shocks. For the rear, look at Commodore wagon shocks or early Monaro rear shocks as both will fit (KE35 anyway)
- Ke30 - Speedo Issues
My KE35 was doing the same. The speedo would jump from 60 km/h up to 130 km/h down to 30 km/h. Thought I was pissed. Pulled the cable out and did the grease thing and it was all good. And I did say try. I didn't say it would fix it.........................
try a small dob of grease on the end of the cable where it plugs into the cluster.
- Ke30 Grill
- Ke55 Engine Need More Power !!
- V8 Ke30..
How To Bike Carb A 4K
Used to a Civic in Ballarat that ran bike carbs. They used a header tank in the engine bay to gravity feed the carbs. Fuel was pumped into the tank and a return line took care of any excess fuel.
Steerfast Rally Ke30 2 Door
Please, gotta hear this thing in anger!!!! Where is the "This thread is worthless without video" emoticon........... I'm seriously jealous.
Club Rego In Vic
^^^^^^^^^^^^^^ or Find a car club in your local area and contact them. Some will not be happy if all you are joining up for is to get cheap reg....
Suggestions For Custom Made Pushrods
Couldn't get a hydro cam grind??????
Fastest Corolla In The World
Backed off at 160kmh in my first KE35 (5k, modded 3k-b carbs, exhaust etc). Shit myself as the windows got sucked off their seals at around 140kmh and the wind noise trippled ............. My ke20 club car would cover around 2km of dirt track in 90sec - about 2 seconds slower than a modified STI spec WRX
