Strange Oil Pressure Issues - Help Troubleshooting
Sounds like a broken seal in the oil system. Usually where the sump pickup bolts on, or the o ring seal between the front case and the block. I know nothing of 5m but someone who does should be able to tell you where to look. I guess in theory a heavily worn oil pump could cause this also, but I have never heard of it.
1jz Ke55
Yep awesome!
The Rwd 2Az-Fe Thread.
Sika cracks under paint mate, if you plan on painting it probably better off glassing it. Looking good, so close now!!
Wiring Gurus, Please Help Me Get My Car Started! Custom Wiring.
You need more info than that, search for the full engine wiring diagram. Its pretty basic from memory. Then create an aftermarket relay and fuse area under your dash. Or alternatively and much uglier use the nissan fuse box.
The Evorolla
Start your own thread mate, will be keen to see more.
Headlining's
Corolla headlinings cost me $120 from the local upholstery bloke. He is not known to be cheap so i doubt it would cost much more than that anywhere. Catch is you need one for a template to give. If you want exact original though it would be worth paying the extra $$. Headlinings shrink after being off a car for any length of time so 2nd hand is not really possible.
Blzbubs Aw11
block temp alarm is the only way i recon mate, water temp gives you nothing when the water isnt there. http://www.ebay.com.au/itm/ENGINE-GUARD-EG01-1-Temperature-Alarm-Single-Sensor-Buzzer-Digital-Display-/161730650894?pt=LH_DefaultDomain_15&hash=item25a7e5e30e
Blzbubs Aw11
wow, i haven't seen this for awhile, things went well. love mk3's killer offset.
- The Red Baron Ke25
Turbo Manifold And Turbine Housing
Hi mate. Gt3076 is the wrong turbo. You would be over 5000rpm before you have full boost! With your power goal of 200+kw @ wheels the best turbo would be a gtx2863. Use a .63 rear housing and you can use an internal gate too if you like. It will have great response and can go well beyond your power goal.
Japanese Car Values
That corona looks great in the pics, i would pay that if its as good in person. As for the 30k celicas, they are a special breed i guess, the example shown even in the pics does not present that well. Dreamers
2Jz Ke38 Project (Caged, Glide, 42Gtx) 700Rwhp
Yikes. Did the caltracs fail or something. That sux!
3Rzfe Into Ke70 -
3rz turbo would be legal in a ke70 under the new rules, should happen more often imo. As for the hilux diff, you use the whole thing, not just the centre. A really early rn20 diff is similar length to a ke70, but are very hard to track down, and are also known to have weaker axles than the later versions. If $$$ is not a big issuer probably better off shortening a later model one really, the later one is also more likely to come with the gearing you would need.
Blzbubs Aw11
Awesome mate, great to hear things went well. Now time to enjoy!
Benno's Panno
Excellent, any progress is good progress.
Awesome mate, nice update.
Blzbubs Aw11
looking good mate, head cleaned up well, that trick works fine with a composite gasket. Yep std is the bore size.
Matts Ke30......sr20det
bus wheel is awesome!!!!! I've been driving my ke25 to work for months now, as a result I feel very comfortable and confident steering the ke30. They must have some similarities.
Ke20 Coil Front. Rear Leaf / Coil Hybrid. Rear Swaybar.
If you were to remove all except one of your leafs you need to add links to the front leaf mounts to stop the diff winding up. It really is a bad idea anyways. Better off just going to a proper 4 link if you really want to go that way, which can be approved in qld. Or add a watts link or panhard to existing leaf setup, play around with leaf combinations to get a good spring rate, and get some really good shocks to control the springs. This if well thought out is likely to be enough to get the car to where you want it to be.
Thanks Reed, things are going well with it atm, started on the new diff too.
Hey carlos E85 ftw. The supra in the video runs a 10.5 @ 133mph apparently.
- Matts Ke30......sr20det
Downshift circuits and coffee 28/3/15- Blzbubs Aw11
what! who does that, when a guy has a 20hr drive ahead of him you give him a dead battery to save yourself $50. where are you at?- Blzbubs Aw11
Looks really good mate, was kinda hopeing for a m series supra, but this is cool. - Matts Ke30......sr20det
