B.L.Z.BUB
    8270
    155
  1. I put a large washer under the engine mount bolt which overlaps onto the SC mount so it's kinda clamping that corner.
  2. I just cut the SC mount off. There's plenty holding it on without it, haven't had an issue.
  3. What do you mean the mount has to be modified?
  4. Look up KE Conversions on Facebook or Pm Jordanrolla on here, he makes them.
  5. `Just buy heat resistant split tube and put it over it. I have my starter motor wiring running close as to my stainless extractors uncovered and they are fine.
  6. Yeah Ill probably head down about 5:30.
  7. Made a valve crank case vent system so it runs off vacuum but vents to the airbox under boost.
  8. It won't fit on a stock cross member. You'll need modified engine mounts.
  9. Is Masters on on Saturday? EDIT: Yep. I'll probably rock down to that and show off the new teeth.
  10. You might have a buckled wheel. Try putting the rear wheels on the front.
  11. I have ST Celica front ultra low king springs in the rear of mine. Rated at 4.6kg and sit it at this height on 15" rims. You'll need shorter shock all round whatever you do so upgrading the entire front struts would be your best option. Rears are easy.
  12. I spent about 12 months trying to find a fault and it was a dodgy MAP sensor plug. Could have been worse :P
  13. Rollaclub is predominantly aussie based. Try Club4Ag or 3tcgarage. Also all of your ones would have T series engines (for the most part) and are usually TE7*'s, same car different engine.
  14. Most clusters will bolt in and plug straight in but on the DX/GL (and most pannos) they need to be completely re-wired.
  15. don't look very dished to me? I thought dished pistons looked like this.
  16. It all depends. I've seen 4k's with flat and dished pistons. Same with 5k's. Looks like you have flat pistons and a dished piston head so your compression should be quite high. Someone's tried to lower it a bit with the 'head spacer'. Though don't know what you mean by that, I'd assume they're just using two head gaskets?
  17. Please refrain from making multiple threads for the same thing. Your other post was moved to the Wanted To Buy section. EDIT: A proper thread title instead of just 'Wanted: parts' may also help your cause. :locked:
  18. Dilute some bleach. Spray it on.
  19. Amazing work, didnt expect this result. So good.
  20. I'll take the first 2000GT please if we are putting in orders.
  21. You need a CE70
  22. Well they kinda made the GT86 so I doubt we'll see anything else. Also with the FT1, the AWD turbo GT86 and rumours of a 4 door GT86. I wouldnt want to end up with a PT Cruiser version of a retro Corolla.
  23. Was quite lucky all I needed to do was put the stock one back on. Had a replacement keyway handy too.
