8270 -
155
Track only? 2Jzgte into a ke70/ae86 can't be engineered. I assumed you were in Aussie, but you said ke70 coupe, so I'm guessing you're somewhere that got the ke70 2 door sedan?
Cluster/heater were T5 bulbs from memory.
New wheels on. Gotta dial the camber out of the rear as the offset allows for it, maybe less wheel spin after. Installed the sedan indicators and lower grills. Also put the stock lights back in. And did this for fun.
Hell yeah, awesome.
Got some new wheels, Rota P45R2 in 18x9.5 +20, will hopefully have them on this weekend. Put rear coilovers in to drop the rear down to match the front. Bought some S2 R33 sedan indicator/fog lights for stupid cheap, not installed yet. Also got a duck tail/drift lip, and clear rear garnish.
Love the 86 want the daily more ! We need to cook!
New door will be off a slant front ke70.
Not a photo but just did the rack ends and tie rods on the missus' RAV4, probably the most flogged out rack ends I've ever seen.
They made KP's till '84 taz. If it's a k50 it'll bolt up to the engine, you may run into crossmember and gearstick location issues.
Most likely your starter circuit is old and Tired, very common problem for older cars. Try this, should remedy the situation unless the starter itself is shot. http://www.mk3supra.org/topic/10-guide-start-relay-mod/
I put that lip stuff on my skyline. The double sided tape stuck for a day before I had to screw it on. Then one day driving through Brisbane ripped it off. Ended up having to make sandwich plates to clamp it to the bar on the corners. It's already badly scuffed up. Low life.
Rookie Questions About Lifters
B.L.Z.BUB replied to MickCStephens's topic in KExx Corolla Discussion
Or, y'know, put it over the oil filler hole 😁 -
It's cool for P platers, just can't do engine performance mods that require a mod plate.
I'm guessing it's a ke55? You can put a ke70 gearbox in it but the shifter sits further back. So you'd need to cut the shifter hole out a bit to fit, other than that everything will bolt up. Edit : you looking for auto or manual?
I am erect.
If that was on the ke70 I'd guess the whole thing is rust now after he crashed it into a wall.
The exhaust headers on an ae71 are on the opposite side of the engine compared to a ke70. From about you front foot wells back it will fit, the front will have to be modified to work.
Did they paint that sway bar then wrap it in bubble wrap while the paint was still wet?
Just search for 'steering wheel cover' and there will be plenty in the results.
Yeah this is the 2nd one I've done. They're a bit of a mission to sew on but they come up pretty good considering they're only $5.
Added an xr8 bonnet hump. Some LED/running light/indicators Progression Recovered the stock steering wheel with a cheap ebay sew on kit. Got a drift/ducktail spoiler. Got some pig pipes made up.
Memories. Anyone on here? At the lights at the end of Steve Irwin way and you turned off south down the Bruce. Was in the R33 behind you. Bloody shit crap rotate you c**t EDITED
Without a picture it's gonna be hard to tell. As long as your vacuum advance on the dizzy is hooked up then most likely it's just an emissions hose and you can just plug it up with a cap or a small bit of hose with a screw in the end.
