towe001
Senior Member
    2563
    10
Everything posted by towe001
  1. Well well i was seriously looking into v6'ing my old seca with either the 2.5litre 2VZ-FE or the 3.0litre 1MZ-FE from the camry. From what i could find on the net and some basic measurements (length and width) it would have fitted..... just But all in all i wonder just how close the two models will be in chassis, engine mounts etc - the Scion and the v6 rolla. And how long before someone swaps in the v6
  2. :P Rear hubs are different to the single cam as well so you just can't pull the drums off and replace with the disks.
  3. :P But at least you didn't do the same thing as an old couple did when i was working at a trash recycling center. They brought in this sony trinatron tv (the latest and greatest at the time) it didn't want to turn on for them by the remote so they bought a new one and just dumped the "old" one (around 8 months old from memory), so anyway one of the lads took it home and made about $400 on it cause the old couple didn't check the power button on the tv :P
  4. C52 from the AE102 or AE112 Was used on the 1.8litre models (well thats the aussie stuff anyways) http://www.ae92gts.com/ae92gts_start_reloc.html
  5. WHAT can't hear you over the motor yeah yeah muffler you need a muffler and a resonator thingy as well But really a 2" shouldn't be that bad. Might even be an idea to give the motor a tune up
  6. Try more likely a C50 g'box. Didn't the C52 have two starter motor humps and the drive shafts hook up differently in the box Either way it's not from the MR2 so count yourself lucky there
  7. Suzuki Swift GTi block with the Serria crank and bore the block out 60thou That way you don't have trouble with finding a reverse gear and in "theory" you'll be keeping the motor under 1.3litre
  8. Your joking right A couple of years back the residents of Maroochydore/Mooloolaba were up in arms cause of the "hoons" over the weekends so a car friendly councilor started up a petition to get the "hoons" off the streets by setting up a self-funding motor complex. Just about every "hoon" and most of the fed-up residents signed it, the local cops even voted for it - the government knocked it back, too much effort and the money would be better spent on "other things"..... The Gympie driver training skidpan is getting shut down, permanently, in a few years or so..... The rally that gets held at Imbil forestry is more then likely getting the can as well in a few years or so - unless they move it.......
  9. Not being able to see the Wicked Weasel promo girls :yes:
  10. Been there done that kind of crap. Its even better when ya slaving your guts out cleaning down a kitchen well past midnight Never again...... HAPPY NEW YEAR PEOPLES and have a good 1 machg, the scum that did that should be made to wipe it off with their faces
  11. Yeah noticed that one as well. And the throttle bodies are at the back of the manifold, normally their on the left side of the manifold. But its in a Skyline
  12. true, but that little fire truck would have to be something left field more so with Fords 427 SOHC Cammer v8 between the front wheels cherry red with chrome and brass fittings along with two real wood fire ladders hang off the sides :dance:
  13. I'd like to get my hands on that little fire truck and rat it out :dance:
  14. True, cause it looks like the new falcon will be funded by the tax payer just so that it can be built in asia but any what my vote is for REDWARF Ya know you wanna.....
  15. By the sound of it you've got a faulty connection/s somewhere. Is there power coming out of the relay for the lights ? This does happen even for Narva relays from time to time. Have you tried with pulling the bulbs out of the lights and "shorting" them to the battery ? Might even be time to invest in a test light or a multimeter
  16. Can't help either with the codes but it sounds like you've got one thats for the AE82. Fits on the shaft, correct with the splines and all just not the depth.
  17. Like cows herding under the solo tree in the paddock so are shoppers and a price checker....... And just like cows half of them were only shooting the shit under the shade of a price checker machine......
  18. Brings back memories of seeing burnout marks and circle work on the Bruce Highway Brissy side of the Caloundra off ramp a few years back
  19. More so when they're pulled up tight for a sweet as camel toe :fuzz: :lolcry:
  20. Top stuff Des :lolcry:
  21. True, but you guys did get the TE7x versions
  22. How about the rods from the ke70 wagon ? I can't really see the roof width being much different with the sedan or liftback versions either so that could even be another option.
  23. Jason, you should come to Toowoomba its bloody cold outside......
  24. More or less the same but using less wiring. To get the power for the relay you just splice into the high beam wire at the head light (or if its for fog lights - the low beam wire). The relay won't work till you've closed the circuit at the switch. To find what fuse rating you need Voltage / watts = amps 12v / 100w = 8.33333amp (but use one thats a bit higher due to spikes when the light gets turned on, say 10amp) Same goes with the wiring for the spot/driving/fog light. Where as the wiring for the relay/switch combo you can get away with cheap and nasty speaker wire if you feeling cheap and nasty. The relay itself only draws something around 1-2 amps when its turned on But all in all keep it neat, tidy and have good clean earthing (grounding) points.
  25. My wish list that just grows and grows and grows
