Hiro Protagonist
  1. Time for a bit of an update, nothing really much has happened of the last couple of months except for fault-fixing, here are the anti-Cliff Notes presented in fairy-tale form: A long long time ago in a land far far away, a skilled blacksmith and his faithful apprentice warned the princess of the castle that the diff was starting to leak in the faithful steed, and that they should look at replacing the seals. Figuring that this would be a good idea since the diff was a bit overdue for a service anyway, the prince went online and bought some genuine KAAZ LSD oil, and then managed to get a set of diff seals from the kingdom of Amayama. Seeing as how the kingdom was short of time and money, these sat in the boot for a few months waiting for an opportune moment to be installed. Then suddenly one day an evil gremlin snuck out during the night and begat mischief on the steed, and from that day on the steering wheel sat about an eighth-turn to the left when the lion was travelling straight, as well as some devilish sideways action mid-corner. Figuring it was also time for a wheel alignment, the princess booked it in with the “wizards” at Bob Jane for a wheel alignment and wheel rotation. The magic wizards then proceeded to tell the princess that the right rear wheel had eleventy billion degrees of toe-in and so much negative camber that it was on as much of a lean as an Adidas-wearing 180SX driver’s front seat. In their infinite experience and wisdom they explained that they couldn’t carry out the wheel alignment, and that the rear suspension and/or chassis was most likely twisted into the shape of a pretzel. Disheartened by this news, the brave princess and her stately prince returned to the castle with their heads down. After much deliberation and inspection, no discernable damage could be discovered, so a second opinion was sought from the local sorcerers of suspension, a place of apparent repute and masters in dark arts of understeed dynamics and geometry. When it was apparent that some work was to happen on the rear end of the steed, it was decided that the diff should be serviced at the same time, as well as the seals replaced. Almost immediately the sorcerers confirmed our suspicions that the chassis was indeed straight and true, and that the true damage lay in the bushes, which were worn from the years of supporting the powerful and burly steed. Since no bushes could be found to replace the worn ones in short time, the alignment was adjusted to the maximum extents allowable, which was just enough to allow the steed to track straight and no longer bolt for the hills under even the slightest provocation mid-corner. Whilst disappointed that the problem had not been fixed at the source, the prince and princess were nonetheless relieved that the steed could again be ridden in confidence. However, within only a matter of days it became apparent that the newly serviced rear-end of the steed was not behaving in a manner befit of a royal steed. Whilst she would track straight and true on a flat level road, there was an almighty clunk from the rear end in even the slightest of corners under power, and the kick that had previously been a mere annoyance had become wickedly vicious. Inexperienced in the mysterious workings of a 2-way differential, the prince hoped that this would calm over time as the freshly serviced diff was once again tamed. With the royal wedding fast approaching, the prince and princess could not afford the time nor money for the steed to be laid up in the blacksmiths, and from that moment on it was left in the stables as much as possible, only to see the open road when absolutely necessary and ridden with extreme care. After the stress and turmoil of the royal wedding died down, the now king and queen decided that it was time to fix the steed’s evil ways once and for all. Having considered the possibility that the diff was beyond repair, and having a spare factory diff still in the box from the previous owner, the steed was stabled once again at the renowned Nova Auto Innovations blacksmiths shop where this tale began, with the prime intent of getting her re-registered for another 2 seasons, as well as finally getting to the bottom of the curse that was vexing the rear end. With much delight (and surprise) the skilled blacksmith and his faithful apprentice informed us instantly that the heart of the issue lay with the left rear wheel bearing, with a full ¼ inch of float which would explain the wicked kick and god-awful clunking, quite possibly caused by incorrect fitment when the diff was serviced. Despite having to wait over the long weekend for parts due to the peasant’s holiday, it was assured that the faithful steed would be prepared in time for the following Wednesday. And so, a quarter moon after she was first delivered to the stables, the mighty steed was returned to the king and queen fully cleared for registration and exorcised of her demon troubles. It was with much rejoicing that the queen gleefully accepted the return of her steed, and whilst she still has her foibles (the exhaust still scrapes on any bumps larger than a pebble, and the paint needs touch-up after a few unfortunate scrapes as well as a strange discolouration down her left flank) all of these were momentarily forgotten and left to be fixed another day. Cliff Notes: Diff leaked Wheel alignment went funky, bushes were stuffed Idiot 1 said the chassis was bent, got second opinion Saviour 1 said the bushes were stuffed, fixed the diff Saviour 1 possibly turns into Idiot 2 as rear end now kicks and clunks horribly Left untouched due to expensive and stressful upcoming wedding Post-wedding, re-regoed and rear end kick and clunk attributed to stuffed wheel bearing Wheel bearing and hub replaced, now hauls arse once again.
  2. Genuine Sportivo stuff is hard to come by because it was such a limited edition model, not too many of them get wrecked/downgraded and all of the existing stock has already been bought by people upgrading their 112s to the Sportivo body kit.
  3. Correct - the Kelly brothers (and Kelly Racing) are moving to Nissan Motorsport with factory backing, Stone Brothers are partnering up with Erebus to run the Mercs.
  4. Mercedes/AMG aren't officially entering a factory team like Nissan are, it's being handled by a third-party team (Erebus Motorsport, who run SLSs in the GT Championship) with next-to-no factory support BTCC is in the middle of a transistion between Super2000 spec and a Next-Gen Touring Car, both of which are based on road cars (S2000 moreso) but the NGTC has more standardisation in the bodywork (fixed chassis width for instance) and drivetrain.
  5. On this engine it is :P I've always planned to do an engine swap of some kind, just never had the time, money, room or spare car to be able to do it properly. Since the next big thing in my life is a house, things will hopefully move forwards next year, but by that stage this engine should have hit 400,000km and in prime condition to be turned into a coffee table.
  6. I drive a 7A, and when I got my bonus instead of going out and buying a real engine, I kept driving the 7A.
  7. And why should we like it? Are you in a competition or something, or just seeking attention?
  8. You're looking in the wrong spot then (or you're only looking at blacktop 20Vs). You can buy a whole AE82 Twincam or wrecked AE92 SX/GTi for that price.
  9. A little bit of bling - metal grill logo, 1 large stick-on logo (for the boot lid), and 2 small stick-on logos (for the front quarters underneath my repeaters and 1.8L badges) Oh, and a shiny thing-y just arrived in the mail :D
  10. Look around, you should be able to get a smallport head for cheaper than $400 (hell, you could probably get a full working smallport for that kind of price from someone wrecking a whole car). You're just making more work and life more difficult for yourself by trying to adapt the bigport head.
  11. No, he's saying that in normal driving conditions the factory shocks will never extend as far as what is shown in the picture, whereas the short-stroke ones might - hence not a true comparison of on-road stroke lengths.
  12. Or that you can get decent engines smaller than a 6/V8
  13. No hope in hell of street-registering it (max allowable engine size NA under VSI-6 was about 2.8L in a KE55, don't think NCOP is much different), to re-classify it as an ICV you'd pretty much have to start from the ground up with a new chassis at which point there's no reason why you'd use a Corolla as a base anyway. Plus getting an ICV registered is a lot more stringent than getting a modified car engineered (considering you have to prove every element of the car as being road-legal/safe etc).
  14. Actually, it's an RS50, not MS :P
  15. How so? Clocks were put forward by an hour, so if you were working at the time of the changeover then you would have worked 1 hour less than normal for the same start/finish times.
  16. Soarer, Celsior, Crown, Aristo....
  17. I was surprised by the lack of KE3x/5x/7x actually, normally the Radrollaz guys turn out in force, and Marty sweeps the awards :P
  18. Maybe specify what is in the kit? There are little differences between the 4AFC, first gen 4AFE and 2nd gen 4AFE that could mean bits of the kit are not compatible/not required
  19. Don't bother with wreckers, just find someone selling a cheap wrecked Twinky and strip it for parts
  20. If it is MAP just get an ECU and dizzy from an Aussie AE82 Twincam bigport...
  21. The widow's peak on the bonnet doesn't help things either...
  22. Tomato prices are up because the Qld season started slow/late, and the NSW season hasn't kicked in yet. There was an article in the paper about it the other week
  23. Considering the proliferation of shortening words for SMS-speak, I'm actually highly surprised that "brought" and "bought" aren't shortened to "brort" and "bort"... Then again, if that happened they would have to order more "Bort" license plates... http://www.youtube.com/watch?v=9vihYeWip4g
