corollaart
    612
    7
Everything posted by corollaart
  1. You need to also convert to hyd clutch,unless you can find a cable type housing,but are very rare. If you use a ta22 box the shifter position is a perfect fit in to the original hole. Use the 30 rear cross member,just move it back to the rear factory holes . Tail shaft will fit if useing the early t50 box. I had to get longer bellhousing bolts as well,the kt housing is a bit thicker than old k40 bellhousing. Also need a different clutch plate (PBR-7098W) Easy job all bolt up the biggest pain is converting to hydo clutch.
  2. Gold,what sort of tyres are they running look really low profile?for a rally tyre. :y: :y:
  3. Thanks guys :The tube is not tapered at all (55)and is 80mm od,the 132 tube is 65mm od.Rechecked the uni joints thought i mite get away with swapping two caps to get it together,which looked promiseing ,with both measuring 15 mm id. But the t series uni is 4mm longer :bash: Maybe getting the flange machined on the diff is the only way to go I'm out of ideas. Will ring the drive shaft guys again. I'm trying to keep away from getting a custom tube if possible ,for cost reasons.They told me that if all they have to do is shorten it cost will be minimal and I'm all for that. Just thought id throw it out there to see what others have done as it has been done many times apprently. rob
  4. So ive put a t series diff into my 55 coupe rear discs etc ,The problem i now have is trying to get a drive shaft. I thought i could use the t flange on the 55 shaft then get it shortened,but the uni joints are different. Maybe get a hole new tube built ,but the shaft tubes are 10 or 15mm different in size. Maybe mix and match uni joint caps?? I have plenty of ke55 shafts,and one rt132 two piece shaft (tseries flange) Help :hmm: rob
  5. I guess your talking pajero,i had a mate with one that got hot all the time .He took it back to the dealer (some years after warranty ran out)and was told that they had problems with that model. Replaced temp guauge,themostat,and radiator free of charge :o seemed to fix it,not sure what the problem was though. It was one of the first models with the big dakar front guards not sure what year. Mite be worth a check of there recalls.
  6. Also rt132 coronas and some rt104 coronas,much cheaper to buy corona parts than celica parts .As they don't hit ching key on there cash register :rolls: . Even though they are the same parts bloody wollys :lolcry: rob
  7. Can anyone link or tell me the specs on setting up a t series diff,and also best place to buy a kit to rebuild,are crown wheel and pinions still available?? Thanks rob
  8. Time for compression test. :yes:
  9. If you thermostat was stuck closed it would boil its ass off ,as the water flow would be next to zero. May be its stuck open and not letting the water cool down enough before it returns to the engine. I would replace it for the cost of them ,shame you didnt do it when you had the system drained. Then you test the old one by hanging it on a bit of wire,dropping it in to some boiling water see if it opens. rob
  10. How true altezzaclub ,it a real pain to get some where to try out your mods .Wheather they work or not ,and end up trying at the next event. Keep up the good work snot ,you could maybe check out what the stanza boys set up is that would be close to a 70 . rob
  11. +1 ballast resistor had same problem :yes:
  12. Engine mounts ,harmonic balancer,diff sitting at the right angel,shouldnt be that hard track down. Just start at front and work your way back.
  13. Yes it can be done ,there was some one on here that had pics ,I think it was the redwarf rob dixon but unsure. I'm sure he will be along to to put us rite.
  14. M12X1.25X60,M12 SIZE ,1.25 TREAD,60 LENGH iF YOUR USING THEM TO PUT THE ENGINE ON A STAND YOU MAY NEED LONGER THAN SIXTY MM. ROB stupit cap lock.
  15. This is our r/c sos point in shipmans stage on friday ,very wet very slippie.Just ask ogier ,as he said wee have( how you say) no grip. The other picture is car 69 a new evo convertable , in grace stage on saturday ,done 2.5 roll over with a small twist. Ogier and his nav trying to put gaterade in the radiator :lolcry:
  16. pics at the start all nice and shiny.That water crossing ,was that in shipmans stage??
  17. Just back from coffs seen the corolla at cerimonal start didnt see it on any stages??? Hope not engine problems or crash?? any one no?? pics to come soon.
  18. Will need ae71 front cross member,t50 gear box ,drive shaft not sure. Carbs or efi ,how longs a piece of string question . Old guys carbs young guys efi. :rolls: (carb manifolds can be bought new ) Check out build threads been done many times . Budget 1500-2000 $$$
  19. Check the sponsors list. :wink:
  20. Ha opel gearboxs,thought they where forgotton to the pages of history ,as a epic fail. :rolls:
  21. don't no much about these carbs but i would be checking the float level,fuel pressure,also vacuum leak around carb or manifold.
  22. Ok i will see if i can get some pics and or video of car 9 ,i ll be in shipmans friday and grace saturday. cheers rob
  23. So anyone from rollaclub going??I will be doing offical thing ss3,ss6 ss12 ss16 and having a beer or three sunday nite Looking forward to the classics can't beat the sound of webers on full noise thru the forest. Maybe the arc guys will find out what its like to be second fiddle,and un important :laff: rob
  24. +1 Tekonsha had mine for years in two utes allways works and not that hard to wire up. Biggest problem is finding some where to put them. Mines not as flash the one above ,just the poverty pack one ,same with out the displays rob
