Name:
Hi, My name is Dave
Car:
1973 KE26 2 door, 2 seat Panno
Motor & Driveline:
She's running a rebuilt 5k with Tighe cam, Redline manifold, twin side draft dellorto's, Headers and exhaust, KE70 radiator with thermo and a 5 speed.
Suspension & Brakes:
KE30 axles and drums rear, and KE70 front discs, has reset leaves with reversed eyes, Navara rear shocks, modified front struts with SV21 shocks and Liberty springs, and a re drilled K frame for Camber. Has new Ball joints, steering arms, Pitman arm, Idler arm, and all bushes been replaced with Whiteline nolathane items.
Wheels & Tyres:
I've stuck 15x6 front and 15x7 rear Work Equip 01s under it with 185/45s
Interior:
Liberty seats in black, recovered dash pad, average black door trims and carpet, Razo gear knob, TE27 instrument cluster, OMP dish steering wheel and awesome K's meter temp gauge.
Body:
Given a quick straighten out and prime up, blocked and then pained in High Opacity white outside with Holden Impulse blue engine bay and interior (needs to be redone one day as i did it in about a week cos i needed to reg it quick smart), Has TA22 GT guard mirrors, TE27 front lip and a 71 SE facelift.
Other:
It's sweet as tits :D I love it, it's like a go kart to drive I just need to spend a bit of time on the body and clean the wheels up properly one day.
There's more pics of it in my profile gallery if you want to look :)
There's a short poor quality video here :D
Edited by mr04ag
[b]Name[/b]: Isaac Macleod (11 3/4 Yrs old)
[b]Car[/b]:ke20 (mini cobra)
[b]Motor & Driveline[/b]:5k 3k X, twin asian carbies, 3" high filters, MSD, Jocobs HP coil, bosch Idrium plugs, 10mm leads, extractors and 2" high flow exhaust, the other picture is of the all alloy V8 Dad is going to help me put in. nedd more Cubes
[b]Suspension & Brakes[/b]:front, lowered h/d king springs, 3/4 inch sway barand strut brace from VH bommadore and the rear is, VH bommadore pedders shocks, repacked(by me) leaf springs from 4 leaf to 9 leaf, custom rear sway bar from ke70, ride height(barely legal), Brakes are ke30 and 50 X. 114.3 pcd
[b]Wheels & Tyres[/b]:13X7 superlites with 235/50/13 rear and 215/60/13 front.
[b]Interior[/b]:Half cage and race seats and harnesses, the rest is stock.
[b]Body[/b]:lowered, pumped guards with flares, white with Cyan blue stripes, fake FMIC, front lip spoiler, bonnet scoop
[b]Other[/b]:suround sound system and 17" DVD player, 4X4 way 6.5", 2 X 6X9 4 way, 2 tweetwers with splitters and 12" sub and amp, Xplod head unit.
*Put pictures here*
Thanks Teddy! :)
The only pic i have of my baby before i got married.
Yeah, i know, does not fit in, as it is a TE, not a KE.
From memory, Stock 2TG with sequential Mikuni carbs, 5 speed, with non original front flares, non original interior and mixed rims.
Was fun to drive, wish i had it back again.
Edited by Morguemaus
  • 4 weeks later...
Car: 1972 Ke25 / Te27 Replica
Motor & Driveline: Ta22 2TG Weber sidedraughts and T50 forward position selector, Factory Te27 radiator, Te27 driver shaft and te27 T series 3.9 10 bolt diff, custom 4 - 1 extractors 2inch exhust.
Suspension & Brakes: Te27 steering arms, te71 struts and brakes converted to adjustable coil over suspension, T3 RCA's, T3 camber plates, 2 inch lowering clocks in the back, white line rear sway bar.
Wheels & Tyres: 14 x 8 Front and 14 x 9 Rear Volk Mesh 0p Toyo TR1 rubber
Interior: Te27 200Kph rev counter dash, Te27 3 Guage heater console, Te27 Sprinter glove box lid, Te27 Center console, re-trimmed to JDM spec Front and Rear seats, Te27 over head light unit.
Body: Te27 Hydrolic pedal box (have to say a big thank you to Redwarf your build thread has been very helpful in getting the pedal box in!), Te27 Sprinter rear guard vents, 100mm flares, Te27 Trueno Tail lights, Te27 Sprinter bonnet vents.
Other: Once I have her back on the road Ill be building a 2ltr 2TG using a later EFI 2tg 3t crank, fordged rods and pistons but keeping with the induction carburetor configuration to keep the factory look. Will also be hunting down all the other JDM Te27 bits to complete her.
On the Road
Edited by modify
I'm not sure if you've realised, but your wheels might just be the slightest bit too wide :hmm: lol
Are you saying I should run my 13 x 8'S?
imgp5344.jpg :rolls:
Edited by modify
Those pipes are awesome! Did you make them yourself mate!?
Pfft not to wide enough lol! Seriously though, there is a bloke on here running 13x10s inside TE27 flares. It's amazing what you can do with the right offset ;)
No way!!! Thats crazy! Did he tub it? Must have shortened the diff too? Could you post the link I'd love to see pictures.
back in a 20
-stock KE30 3K with a bit of an exhaust
-4 speed
-KE30 hubs/brakes/machined axles
-13x6 Jellybeans 185/70
not many plans it's a cheap daily. TA22 fender mirrors, drop, 13x6.5 Mk3, 165/60
currently making few repairs
Edited by benzo
post-716-0-80177500-1327920717_thumb.jpgName: Greg
Car: 1973 KE20
Motor & Driveline: 5K K50 5 Speed CIG 4:1:1 Locker
Suspension & Brakes: Stock brakes. Front 2" Lowered King Springs Monroe Gas, Stock Brakes with VH40 booster, Front K-Mac 30mm Competition sway bar, rear has K-Mack sway bar, all have Nolothane Bushing, 63mm lowering blocks with HQ Holden air shocks, I can sit it at just about any hight I like, rear strut brace & home manufactured pan hard rod,
Wheels & Tyres: Centrelines 185-65-13 Also change to 13X8 Superlites or Mazda RX4 Steelys with 185 BF Goodies and granny hub caps first pic, and I also have a set of 5 1/2x13 Bathhurst globes for it,
Interior: Pretty much stock: Has New door cards front & back fabbed by myself, Smiths vac, volt, and oil gauges, KE25 under dash parcel shelf, Celica TA22 LT centre consol, saas 1 inch steering wheel, Toyota corolla KE20 Factory Optional dash mounted tacho rare as, Pioneer CD 400 watt Sansui amp home made 3 way boxes in the back, snazzy retro brake and strobing indicators in the back window 'sooo coool baby' new carpet still waiting to retrim front seats back to original,
Body:Stock except has 72 bonnet don't seem to rust as much as others i've had, resprayed 6 years ago stock tojo yellow.
Other: Motor has been fully balanced and blue printed, is as single squish 0 piston motor with twin 40dcoe webers bolted to a 3K worked big port head, hurricane header from Liverpool exhaust centre, 2inch system with hotdog muffler, 4K-E electronic dizzy, GT40 coil with top gun leads, Facet electic fuel pump, VS Commodore thermo fan run off Davis Craig controller, fan fits perfectly in stock fan cowl, , will eventually have TE27 fender flares to fit my 13X8 superlites under so it doesn’t attract mobile disco’s with a government invoice book, Future mods just freshen up the motor with new rings bearings oil pump shimmed, solid lifter conversion ordered 3F solids from Autobarn Taree $8 dollars each, and definitely a good midrange to top end cam grind, head shaved a little and just generally tidy her up again the dreaded cancer starting after 6 years with no garage, will need some attention soon it's not bad has a few little bubbles but best keeping it under control, that just about covers it for now, I want to keep it stock looking for now.
Updates: over the past 12 months I've added a SC14 Supercharger, it blows through my Webers which I turbo peeped by adding boost reference lines to the float bowl covers to the planum and rubber cover plate gaskets, buy doing this prevents the floats collapsing under boost, the fuel is supplied with a VL EFI Turbo fuel pump running through a malpiassi fuel regulator, boost retard is controlled by the retard unit on the KM36 electronic distributor, this system works very well with no lean out and truck loads more torque, the charger is mounted onto a slightly modified 7K aircon bracket, I've kept the magnetic clutch on the charger and it runs at 8psi at the moment, eventually the charger will be activated at just after half throttle with a simple no/nc limit switch setup, I do have a 7KE injection manifold but I'm goin to run with this setup for now, while its running sweet anyway,
Cheers Greg.
Edited by 5KKid
Car: KE26 Wagon
Motor & Driveline: cammed 4k,3k bigport head, 5spd 'box. (plans of side draft, exractors)
Suspension & Brakes: standard brakes all round, lowered front springs, 3" blocks in the back
Wheels & Tyres: standard 12s with chrome trims
Interior: black vinyl
Body: usual rust, commodore alpine white.
