Everything posted by cuzzo
What Grinds My Gears.
Clip which holds the speedo gear onto the output shaft.
1j Or 13bturbs Into Ta22
I'm just putting this out there but this 1j idea wont happen. 1) its not legal 2) its expensive 3) millions of other reasons Find someone with a 1jz in their car and ask them how much have they spent on it (including car purchase) Anything with a 1j in it will cost minimum 8K. Either factory installed or converted.
Johnnyt's Sr20Det Ke30
Where did you get info about the wheel spacers mate? Its pretty unsafe running slip-on spacers even if glued with anything. Get wheels that fit and do it right.
Busted Door Lock
If lucky enough find someone else with another rolla wrecking with keys. Swap all of the barrel over except for the ign and have two keys. Fit solex locks and have a different key for the ign. Getting a single key is only possible if you drill out the screw that holds in the ign barrel and replace. (not fun)
21-bjf's Ke20
Yeah it looks great. Looks like you have some great help out there.
Fook me. Atleast these ^ rants are in the correct thread. What grinds my gears? Having to replace a gearbox for a 2dollar part. Yay for me.
Car Acts As If Has Dead Battery, With Charged Battery
No hard to rip out starter. jack her up, unbolt it, (make sure batt cables are removed already) Rip it out and test the starter motor with jumper cables to the battery. You will only need to touch it on the +ve (with the -ve earthing the starter) and see if its engaging and spinning at normal speed. If yes then put it back in and continue looking.
My 4agte Ke25 Project
w57 have mechanical speedo drive. You need to find an electric one from a cressida grande. either mx73 or 83 can't remember
George's Ke55 Coupe Sr20det
Looks tuff bud!
Oke020
To appreciate how nuts this is you need to see videos.
Oke020
I bought Zoom. Just doesnt give it justice.
whats the condition of your terminals? Are they dirty/corroded? Clean them up with a wire brush if they are dirty and then try. Make sure you bolt them up tight too.
13Bt_Ke20's Ride
I'm guessing you didnt cut down the lux diff.
Oke020
Hey, Have you strengthened up the chassis apart from the roll bars? If yes how so.
Ke Ping's 2nd Rolla - Stocko Runaround Ke55 Sedan
Hey bud, Nice buy.
Josh's Uzs131 Toyota Crown
Tuffff with 4 ff's
Pick & Payless (blacktown)
Just don't only ring up though. I rang up one week. me: "Got any ke30's?" him: "no" next week going past, stopped in. had like 5 of them. fkers
Ke10 Ca18det
This thing has come to a radrollaz cruise hasnt it?
Ke10 Drag Car Pics As Requested
Wow this thing is beautiful! Please let us know when your going out next.
Damo's Ae82 Twincam
Impresses with the crossmember. How did you work out exactly where the motor should sit?
Ke30/55 Chassis Strength
I'm making 200kw atw. no noticable chassis twist but i havent measured it. Its very possible it is twisting. Remember the more you strenghten the chassis the more snap over steer you can have (depending on driving style of course)
Ke30 Key Barrel
If you don't have the key you may need to drill it out.
Esp Mind Experiment
Agreed. If you can't work that one out go back to school.
A Must Watch For All Drivers
That shits f@$ked up. That last one is detailed.
Toyota Nationals 2009
Driving the corolla for 3 hours is bad enough..... Maybe if i had a 6th gear.....hmmmm *eyes off lexus box*
