What appers yellow probably used to be white.. Colors according 74`ke3 diagram External regulator.:
White Green - F
White Black - E (ground)
White Lightblue - N
White (a seperate fatter one, not part of the plug) B
Good to see the forum is still upp and running, helpfull as always. Worth mentioning that if fan size or position is changed, shroud should be modified accordingly for effective cooling
Jap diffs: ke1 and early ke2 had B code. Late ke2, ke3, kp61 and ke7 had U code and kp60+ 62 are X -code 5.6" U and B axle splines interchange but not the X code splines. There was a Finnish shop selling new 6" lsd centers. Forgot the name but will probably pop upp when I least expect it ; )
Media loves exaggerating Facts don't sell
There has been talks of banning sale of NEW diesel and petrol cars in norway from 2025 but nothing decided yet.
There`s no mention of when old ones will be prohibited
Lots of New electric and hybrids being sold these days due to small or no tax, tollfee, parking expenses ++
so owners of ICE cars subsidice El cars. Not happy about it as I got six of them.
Kentcams sell single valvesprings to suit the T125 : VS35 and adjustable pulley : S63
3F lifters and "Twin squish 4k pushrods" are the parts Toyota originally used in their solid lifter vertion of 5K so wouldnt call it mix and match.
Keeping Hydro lifters would need a different cam grind and New or resurfacing of lifters
jap banjo diffs have a ID code starting with a letter followed by three digits. .
Indicates Crown diameter, ratio and lsd or not
E7 Corollas came with s,t and u code diffs.+ borg warner for ADM
http://www.club-k.co.nz/Forums/viewthread.php?tid=10452
Hi.
kp6 hubs are straight swap. ke3 hubs need a different bearing as said. .
Id look into using kp61 brake disc and caliper as theyre bigger and better.
I don't know if brackets fit strut
Cheers
Yes, you can measure from input flange to housing flange. S : 195mm T : 225mm
http://www.club-k.co...d.php?tid=24477
Also, should be stamped on alu I.D tag on firewall
Saw there`s a good S series r&p set for sale in finland at the moment . Probably wont find lsd for it tho.
S : 8 stud housing flange T: 10bolt housing flange
Hi
Suggest you get a 1.3 4k from a ke70 instead of spending $ on the 3k, if youre planing a smal uppgrade.
This might be a decent one: http://m.finn.no/bap/forsale/ad.html?finnkode=61125638
early ke20s are B , later ones are U,
Did some Research some years ago and found that
U heads should fit in your B housing using B (original) axels
U : late ke20, ke30, ke70, AL25, kp61
