jono1986
Everything posted by jono1986
  1. Ummmmm fo shizzle .......stab in the dark that was
  2. Another update on the Rolla, just fitted lower springs to the front last night. Much better than before, but not too much of a drop. Gonna fit some new ignition bits very soon, hopefully. Here's a before an after pic, SO happy with how far i've come with it.
  3. Google it, it is a muffler, and not everyone can go out and buy a welder. Steve get one of your mates to have a look at it, the muffler should just be welded on where the last one was and do the bracket as per original. Take a photo of the original setup and the new 'backbox' then we can be a little more descriptive. Jono
  4. People that go 10km/h under the speed limit in overtaking lanes.......
  5. You have to have a login man.
  6. Look up the cost of a full air bag system, and it's something that should be done by a qualified auto-elec. Cause in the end those things can break bones if they go off when you don't want them to. Knowing what's in an airbag system i would not bother, just get a later model car tha has them standard.
  7. Made a program for my calculator a little while ago to do this for me but roughly: (Litre / distance) x 100 = L/100km i.e. (38/400) x 100 = 9.5L/100
  8. Any update on this, like is there a place south of the city people can suggest, and what kinda prices have people been quoted?
  9. I take mine back, maybe have the Veyron as a Daily....but the have a Veyron Super sport for weekends....just saw it on top gear....i'm going to make love to that car
  10. Hey guys old thread but are all k40 and k50 rears mounts in the same position, through the range of ke30-70's? And are they all big hole in the middle and two 8mm (i think) either side of the big one? Cheers Jono
  11. If one side of the front bumper is closer than the other that means the brackets are bent, are the brackets 90 degrees to the bumper?
  12. If the face that touches the rotor comes out atleast 5mm you should be alright, don't know about your rims but my dragways were hitting the caliper so i had to upgrade to girlocks.
  13. Wow....just fitted a new driver 1/4 panel and front lip....JEEZUZ that was so much more difficult than i thought. Had to move the door like 5 times then the front lip was different to the one that was on there, but all good and so happy with the result. I'm getting a massive love hate relationship with this car, but it should pay off in the end. Here's a pic of it now, it's taken from that angle cause i had to rest the phone on the ground.....so sleepy... I'm replacing that door so I might just spray paint that strip white to get rid of it.
  14. ummmm.....Bugatti Veyron......
  15. For Crankin bass http://www.youtube.com/watch?v=Lrmf283dSXw Maybe the best driving song ever.... Something Weird... http://www.youtube.com/watch?v=uki-hOrO3AA
  16. People who have their high beams on in the city..... People who give way to their left on roundabouts...... and finally haven't read the rest of the topic but....YOU AMERICA....f@$k YOU!
  17. I know stuff all about that ^^^^....... But thanks to Tax time I can survive another 6 months of uni without having a job. And maybe thanks to Tax time for maybe new suspension....maybe Oh another thanks to Tax time for being able to buy shampoo.....
  18. jono1986 replied to Jared's topic in SA / Adelaide
    :yes: :yes: Gettin some supplies.
  19. Thought i'd have an update, has been a while. Just had the car tuned and is running so sweet, and now i'm onto some projects for it. Both of the ones i'm working on are the result of boredom whilst on holidays, one of them is reasonable and the other is 'just cause'! This one is an Accessory, Ignition and start switch panel with LED back lighting and Status LED's for ignition and accessories. It will fit in the centre console just behind the gear stick with relays located underneath the dash to switch the original wires. And this is a VR dashboard, and this is just 'cause i can' sort of thing. It has turned into something quiet complicated as well the dash is for a V6 not a 4 cylinder, the speed sensor needs to be electronic, the temp sensor is the easiest (just plug and play) and the hardest of all is the Fuel level sender. The fuel level resistance difference between a VR and a corolla is that it is inverted on the VR and of higher resistance, Guageworks say they can recalibrate the system for 90 bucks but i reckon i can design some electronics to do it for me. Also i'm using this dash cause it has no CAN connections and it's quiet simple. (this is at the cutting edge of complete boredom, and being pov). If people are interested in this conversion I will do a write up, AND it doesn't have to be a commodore dash, just one without CAN connections as it is much simpler to convert.
  20. Hmmm...i might drive over and steel that shell, looks heaps straight......really jealous.....Engine bay looks tired though but in time it will look good.
  21. Is air bubbles in the radiator another one or?
  22. Man that's a good price, i picked mine up for 400 and the only thing wrong with it was the exhaust gasket was leaking, 8 bucks later all fixed. Rapid ticking most probable cause is flat battery or stuffed solenoid
  23. Try knocking on the side of the ignition switch and see if that does anything, according to the diagram the radio wire (if that's what shorted out) goes straight through the ignition. Sounds far fetched and quiet stupid but the extra current could of done something to the igntion to make it work for a little while. Make sure the plastic cover is off when you knock it.
  24. Ah thanks...re-read the knowledge base...and yeah
  25. Alot more work involved upgrading from a 3/4k to a 2tc, 2tc is a little bigger than 5k and are twincam, not sure if it's worth it. Someone else will be more helpful...
