Everything posted by tojo2
Strut Inserts For Ke10, Can I Use Up To '74 Model?
check Felixs tips on using Ke2/3 inserts: http://www.rollaclub.com/board/topic/7224-ke11-suspension/ Say clear of Te inserts as they will be too thick for the ke1 strut tube
2Tc And 3Tc Pistons The Same?
"rockauto " is cheap and got most of 3T parts
Will A 2T Engine Fit In A Ke35??
struts,pedalbox,brakes, hydro clutch mastercyl. driveshaft and diff are different as well if you want to get it close to autentic
A Challenge For The Gurus
I probably got the clusters from the same car you got the crossmember off ..
Some came with 2tg from new - search for TE37.
Te 31s use the same as carina ta10-14, wich is mechanically very similar to the ta22s so educated guess would be that the ta22 brackets will fit
Ta22 Diff Into Ke70?
not due to choise of gearbox but due to nose of a T diff sticks further forward than a ke 70 U-diff. ( don't know about the aussie borg warner stuff but should be measured)
a ta22 diff is about 5cm narrower than a ke70 diff. Drive shaft will need to be shortened a bit as well Ta22s came with 6.62" D and 6.7" T diffs. The T diff will be same strengh as a zenki AE86 T-diff and weaker than a kouki AE86 T-diff Belive some AE86s came with the weaker 6.3" S-diff as well. Wear and tear, previous abuse / maintenance and setup of the diff will also be factors of how strong the diff is.
- 4Age Wont Bolt Up To T50?
Te31 Tc Wiring Diagram
Pretty simular stuff.. is your car LHD or RHD, electronic or points dizzy ? Got a spesific problem with it ?
Trd K Engine Manual
Cheers. Saw some 850 pistons with 18mm pins but they were meant for carillo rods.. expensive stuff sounds like theyre a bit high as well
Trd K Engine Manual
do you remember pin height and pin diameter of stock norton 850 pistons?
Gearbox Question
if its got an auto, driveshaft yoke probably wont fit. Might be able to swap over the yoke from ke55 by renewing front uni joint Will need a ke7 k50 gearbox crossmember as well. ... remember putting a spigot bearing in flywheel and bypassing neutral switch. pedalboxes /clutchwire not the same Better of finding a Ke7 donor
Ke10 - Ke11 Dash Wiring
Sounds like it could do with a bit of fiddeling. Crappy wiering can cause your pride and joy to go upp in flames
Gearbox Question
Tailhousings / gearboxes are the same length, ke30 ones just appear to be shorter due shifter position is further forward. That means you can use your old driveshaft with it. If you already have a 5speed in your ke70 you can just switch the tailhousing with shifters over. If not, you will need tailhousing with shifter from a ke70 unless you want to cut a shifterhole 10cm further forward
Crank Shaft Measurments
http://www.rockauto.com/catalog/x,carcode,1278334,parttype,10524
7K Manifolds
will bolt on but likely to need portmatching. Depends what 7k you got .7kc - round ports , 7ke oval ports Also depends what manifold you got - theres a few options. Just get your tools out and find out what you got
Te71 Works (?) Rally Car
yea, like the te7 hardtops . Never seen one live as we didnt get them Will take a decent budget to restore that thing . Spotted this while browsing http://www.carandclassic.co.uk/car/C268000 :cool:
Te31 Locked Diff
sounds like youre all set then :D . Could be a good idea to do a good flush of the housig before instaling new one
Te31 Locked Diff
Most TE3s had S series diffs. So did some of the TE7s. Does the diffhead flange have 8 or 10 bolts ? Also, measure distance (in millimeters :P) between middle of rear driveshaft flanges and middle of diffheadflanges and we can tell you what diff series you got.
3T Twin Side Draft'S Manifold Hitting Dizzy How To Fix?
aparantly not. Would need an adaptor
Hybrid Gearbox?
Your T50 is newer than his. Before 82/83 was 20 spline and later was 22 spline. don't know date. There`s internal differences as well. Easiest to sell or trade yours for a 20 spline. Yours should be worth most The 22 spline yokes Ive seen don't fit 20 spine axels UJ joint got different width On many 22 spline yokes UJ joints are staked in place rather than circlipped as well.. You could get lucky tho , Ive far from seen it all
2Y Crank For Stroker K Engine?
2Y is 78mm? stroke and 7K 87.5mm so doesnt make sense.. Have heard of modified 4Y crank (86mm stroke?)in 3T tho.
75 Corolla Wagon Problem
They might need this info on sender unit : Float position full = 3 ohm +- 2ohm Float position half= 32.5 ohm +- 5ohm Float position empty = 110 ohm +- 8 ohm
