Redwarf
Everything posted by Redwarf
  1. Fook, is that doing the Bathurust Hillclimb? I think they run it backwards up Conrod....
  2. Gee Dan. You really know how to win friends and influence people don't you? Would you like to alienate anyone else on the board? You're doing pretty well at the moment.
  3. Well, having seen the item concerned, I know that it was onw piece from manifold just aft of the manifold to the back of the car. No joins. Hence my comment.
  4. Sounds like a thronomister problem.
  5. I'm impressed! How did you go around the back axle? Did you chop it in half and use Coke cans? :'(
  6. St Nick, I do believe you are right, and I may be wrong.
  7. And another from a time when 700hp was barely enough. A bit grainy, but the first shot of Walter Rohl is legendary.
  8. From the time when men were men and trees were nervous, I bring you the "whistling pig".
  9. The only one I know of was the 150E twin cam, and you'll never see one of those.
  10. As previously stated, no such animal. Not for a 4K
  11. God created auto electricians to help with problems like this. :)
  12. Not entirely correct. Yes it means that the speed limit is "de-restricted" to the state limit. In most states being 100, even though there are usually sections of 110 road, it only derestricts you to 100. Unless you're in the NT.... :)
  13. Can lend pipe and mofo breaker bar if required. Redwarf Motorsport, tool providers to the stars!
  14. Nut-serts are a threaded barrel that are squeezed into place like a pop rivet. Nut-serts rock. I rate them even higher than cable ties!
  15. I hope you used nut-serts... :)
  16. KE25 3c PRC rally car, and the remains of a TE37 replica rally car. Lockwire is steel wire that goes through a hole in the bolt head, and locks the bolt in the closed position. I'll see if I can find a piccie.....
  17. I lockwire everything that can't be secured with a ty-rap! :P
  18. .... and if you're really paranoid like me, I lockwire them on the race cars....
  19. Ummmm.... The guy is in California. I'm sure there is someone local that can help.....
  20. Corolla Manual states "Caliper assy to support bracket: 54Nm (40 ft/lbs)" That's for standard, I can't see why that wouldn't suffice fo your application. Oh, and I'd use spring washers. R.
  21. Jason: Tight. If you're paranoid about them coming undone, put a dab of locktight on them.
  22. I know that the Ae101 came with 13's, and the only one that came with 14's was the RV.
  23. Easy Tiger. We've established this fact. I'm moving on. I hope you will too. R
