irokin
Admin
Everything posted by irokin
  1. Brand new SARD 700ccs are only about $90 each ex japan. Other than that the biggest top feed low imp factory injector I can think of is GTRs (440cc) or maybe RX7 but they range from 460cc -> 680cc in both high and low impedance.
  2. Basically I use kW x 2.08 = smallest injector size for target power. Usually you end up with a duty around 90% for an injector this size. So 250hp is roughly 185kw meaning the smallest injector is 385cc. 52mm is pretty small! I'd be hunting down something more like 70mm at least.
  3. What kind of HP are you chasing? I'll calculate a safe injector size for you. What diameter are those throttle bodys (mm)?
  4. Hope you have a good one ;)
  5. Sounds like hes just neglected to reconnect a vac line somewhere. Fluttering wont kill your turbo...
  6. No point deleting it. Saves others asking the same questions over and over.
  7. You'll find there's a number of race track owners that are hesitant or will outright refuse to hold drift events. The track damage is obscene and massively expensive to repair!!
  8. Phil Goulds a freaking moron. I was more interested in talking about Cisco routers with a friend than watching origin. G33k Much??
  9. OK I'll supply the motor and you can supply everything else to run it. Heheh I think I got the cheapest bit :yes: Most modern DOHC motors are actually pent roof
  10. Or click this link if you can't find it: http://www.rollaclub.com/board/index.php?s...amp;mode=linear Usually happens after you click a google link. I've got a new robots.txt that should stop google doing that!
  11. Seems to go alright Jip! Car looks great! Will look even better with a good set of rims.
  12. Oh...I thought it was gonna be something important like "I'm a raging homosexual" but noooo :D
  13. I hear Cosworth are selling off some surplus F1 V8s... 2.4 litres should pass engineering. Shame they're a bit over $100,000 for a "used" one.
  14. :D Thats globalism for ya!
  15. Does he mean the release pivot? Those things break a lot on SR20 gearboxes. Basically if we upgrade the clutch we have to change the pivot to the nismo chromoly item or risk it snapping. Looks like this:
  16. Thanks Taz... but its actually 137E (according to cammo anyway lol). Anythings better than 3K-R but *shudders*. Makes it seem more closely related to a 3K than it actually is... :D
  17. Something like 900 & 1800mhz for GSM and 850mhz for 3G. This is so ridiculously fake. I put money on that you could stick the popcorn in an exposed tower feed cable and NOTHING WOULD HAPPEN.
  18. irokin replied to Des's topic in Rollaclub Rides
    Check your axles running true and that the bearing isn't damaged. I got a fulli sick drift damaged diff, axle was BENT and bearing was uber farked. All it had visually was a bent panhard and buggered rim...
  19. I will not have any advertising regarding that guy. He's been nothing but trouble...
  20. Looks like its sprayed upwards to me. Is that the oil pressure sender there? or a knock sensor?
  21. Not gonna elaborate? Edit: Might have something to do with google and/or yahoo deciding to recache the ENTIRE site. Data usage went from normal to 500% overnight :P thats a CRAPLOAD of data!
  22. This is about as easy as engine conversions get! No firewall mods, no trans tunnel mods and you should be able to stick with your current gearbox. It probably will require exhaust modification because they have a higher deck height than the 3K IIRC. The 7K definitely does but not 100% sure about the 5K.
  23. Lets keep it to your own personal random photos people. The point of the thread isn't to just find random things on the web.
  24. I'm wondering if its even legal to copy them... :P
  25. You will learn very quickly that ignorance of the law is no excuse... Don't get me wrong I still think its pretty ridiculous.
