Everything posted by 7000rpm
Electronic Ignition
I would check continuity of the coil using a multimetre
- Toyotafest 11 - Sunday 5Th October 2014
Which Engine For My Ke55 Coupe
Thanks for that. So you didnt find any flat top pistons in that size? I'm building a track car with twin 40mm sideraughts, so comp is key I have what seems to be a big port 3k head, ports been worked to 32mm
Altezzaclub, can most 4ks take the overbore to 5k?
Hi Ben, A 5k is the most straight forward easy swap. Gives more torque due to larger bore size.
Twin Carbs Vs Single Carbs (Stock)
It would help volumetic effeciency because you havent got 4cyls trying to all feed of one little carby.
2T Into Ke55 Swap
Cool, well done. Can you post up pics and briefs on mods you did to make it work please?
Dyno Sheets
Ranko thats awesome power out of a 3k. Well done! Must be some good engineering in that motor
Scanos Ke35 Project
So what cam spec did you end up with? Liking the sound of this engine build, cmon mate, get this going so we can watch it on youtube!
- Ke70 Strut Tops Onto Ae86 Coilovers
My Starlet Kp61
Nice build, so i imagine you need to deck the head along with those pistons to get 11:1?
My Starlet Kp61
Are they stock 4k flat tops?
2T Into Ke55 Swap
When i had my ke30 back in 1997, my mate had just done a rebuild on a customers ke wagon that had a 2TG with the solex sideraughts. We had just finished rebuilding my worked 5k at the time. The 2tg went so much better in stock form, i wish i had done the conversion instead. I reckon a well worked head with good compression would be awesome, working with technology that matches the era of the car.
4K Electronic Dizzy Tacho Fittment
From memory the tacho gets a signal from the negative coil terminal
- Ke70 Turbo Sedan Project
