Everything posted by coln72
Upcoming Events
It was at the sale yards I had to wear the helmet. It was a "motorkana" but I hit 3rd on one course :) Never had to wear one on the dirt.
What Grinds My Gears.
Went through this years ago when they stopped making 225/60/13's. Had to ron skinny 205's :(
and I couldn't ride one back then either................
Upcoming Events
You need a cage to do an Autocross now. Times have changed. But then BCC made me wear a helmut for a motorkhana......
Jaycar O2 Digital Mixture Display Kit
Tried looking up Silicon Chip mag. Often a lot of Jaycar kits have been tested by the magazine and they describe them in detail.
Acc Cable
Yep, can get them made to any length with any end on them you want.
Ke3X Steering Maintenance
I'd take it slowly and check the feel of the steering as you go.
Back off the lock nut on the top of the box. Use screwdriver to tighten adjusting screw. Tighten lock nut. Or Remove top cover, fill with grease, refit cover............. :)
Ke70 Wagon Roll Cage
Would have to be custom made - or start measuring up the width and height of roll cages to see if they will fit. The mounts would be all wrong though................
Ke Corolla Banjo/jap U Series Diffs
Yep that works. Only need to machine off a few mil for it to work. Can only use jab axels in a jap diff or borgy axels in a borgy diff.
4K Power Upgrade Options
Its just reconditioned officer. The bore was worn so I had it machined out to the max it could go to, same with the head................
Ke25 Coupe Rear Shocks
Monaro/early Commodoore should fit. Probably find that its hitting the bump stops if it has had lowering blocks. That will kill any ride comfort it had.
Upcoming Events
Here's another one. Ballarat Festival of Motoring - includes motor show, show and shine and speed events. Cavalcade of Transport - 25th Aug in City Centre Display - 30th Aug Show and Shine - 1st Sept and other stuff. www.ballaratfestivalofmotoring.com.au Typical Ballarat though, bit pricey.................
Distributor Query For 5K/3K
should
At least they told you. They cancelled my number without notice, only found out when I went to get credit
Ke25 Diff To 114.3 Pcd & Disk Brakes
What width is a Sigma diff? Right stud pattern and GSR's had rear discs. Would need to convert to leaves though.
Ke55 Race Car (Trolla)
Like your style. can't be bothered taping up the locks - just paint them :)
don't park in the sun, people wont see the grinder marks in the boot lid..........................
I didnt get a choice of colour. Anyway, if you don't wash it, people don't see the dodgy bits :)
I would but my KE20 was painted in a custom colour with gold pearl. Gotta love cashing in favours :)
Nice :) Guess its white?
Difference Between 3K And 5K Water Pumps
You can press off the flanges and change them if you need to. Anyway, if you run an electric fan, you can ditch the engine fan and it wont matter what pump you run :)
Us mortals never went that fast Rob ...... :all hail:
B A S T A R D!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Never actually measured it or anything technical, but I'm guessing it would of altered with the relocated front pivot points. They were moved up and out. PS. Snot and Jimmi - one of you needs to change your pic. I'm confused as hell!
