SLO-030
Senior Member
    4683
    16
Everything posted by SLO-030
  1. Sounds like a throwout bearing. Only part that really only comes into play (and hence shows its condition) when the clutch pedal is depressed. Best off replacing the lot. Gives you a good excuse to get a HD or puk clutch :P
  2. Evan, Not all the ends on the clutch cable are the sort where you can pop the end off. Remove the circlip on the firewall and disconnect the cable from the top of the clutch pedal. Then feed it back thru the hole towards the diff. Edit: Pretty much what the post above me says :bash:
  3. Hellllllooooo?
  4. Anything can be done. With enough cash, time and angle grinders ;)
  5. Go for the 5k. Still under the 1500cc cap at 1486cc ;)
  6. 99% are the same up to the collector. After that they change to suit the floor pan.
  7. KE30's weren't manufactured in Australia until late 77. What dash does it have?
  8. Just a thought $lau$, hows about make your own thread instead of clogging up Krytons?
  9. Hopefully replace the front pads tonight and alternator when i get a chance to get another one. Bearings are FARKED.. Other than that, the green terror is going awesome. Weber back on this weekend too hopefully :P
  10. I'm running a very similar size (235/60/14) on the rear of my ute. Ended up with Hankook RA03's or something $175ea when i bought.
  11. shit dude. Definatly hope your ok. Such a sad end :( All the best. EDIT: Definatly upload a pic of the rails. If it can be saved, give it a go!
  12. So parts are up on boostcruising too?? Swaps for a fishtank?
  13. Yea. Heard along the grape vine that this thing got sold today. See where it pops up i guess .
  14. Just spent HOURS reading the whole thread from start to finish! All i can say is WOW! Great work guys, the amount of time and attention to detail is just stunning.
  15. The one on the City side is Extensive wheel services. Also seems that they are quite a bit cheaper than Adelaide wheel and rim...
  16. I sent a KE70 K50 about 12 months ago. Cost $35 to be sent from South Adelaide to Country Victora thru transdirect.com.au
  17. Adelaide Wheel and Rim Extensive Wheel Services. Both Located in mile end.
  18. 30's Looking better everytime i look at this thread! What offset did you go on the new wheels?
  19. More than likely...
  20. Interesting, didnt have to do it when i put the KE70 5speed into my previously auto 78 KE30. But the KE55 5spd with KE70 rear housing is rather close to the floor in the original manual 38.
  21. Wanna make me some SKD? :P Giving me some good ideas too, cheers!
  22. Any good diff shop will be able to redrill axles to whatever pattern you want with minimal fuss. If you're after brand new leaf packs, drop me a PM.
  23. what days have the SA crew booked holidays?
  24. SLO-030
    Spotted
    Still looked pretty good. Nice clean base for a rebuild.
  25. SLO-030
    Spotted
    Cheers mate! Your 20 looks clean as. Almost thought it was Scotty's 26 from the front and colour.
