Everything posted by cuzzo
3rz-fe Turbo Ae71
Are you planning on regoing this?
Ke30 Brake Booster/steering Box/heater Core
You can get the booster and steering box rebuilt. If they are too far gone, you may need to find a used replacement then get THAT rebuilt. Steering box rebuild is awesome.
Done
So I'm guessing this is engineered? Or is the capacity too large?
Need To Borrow 2x Toyota Lifting Hooks
Yep and on my engine the previous owner decided the alloy section was to heavy and removed it by the methods suggested.
Sr20 Conversion To Ke55 Plus Rebuild Plus Pimpage
I'm starting the think all of these problems you are having might be related to that attitude shown just now. Most of the things you said the engineer has a problem with have been engineered on plenty of other cars. Oh and curly is a pretty smart dude and knows his rollas but i guess you don't need his help and you have it all under control.
Ke3x/55 Electrical Bugs.
Check the rear demister fuse. Actually just replace it
- Sr20 Conversion To Ke55 Plus Rebuild Plus Pimpage
can't Get The Wheel Off
I was gunna say depending on removal method, just put the nuts on a little bit to stop yourself going flying along with the wheel
Cam Cover Seal Kit.
Most auto shops should be able to get it in for you, if not toyota is best.
Chestikoph Sr20Det Ke55 Coupe
So that cooler is off centre? Like to stock rad?
T Series Diff N T50 Limits
open tseries diff. 150kw atw drag racing. snapped an axel and wrecked the inside of the pumpkin.
Complaint
Either that or he finds it difficult to walk to the pc with his foot in his mouth?
The Usual 4age Into Ke55
Good to see. The pictures don't seem to be loading though ;)
Phils Ke30 3sge Beams
Wow, I'm shocked. I was following this build and its sad to see mr phil not being able to finish this himself. I respect you and those who will help finish the build off. I would want to same thing if anything happened to me. I wish you and those that loved phil for the strength needed to handle this and to carry on.
Matt'S 7K Ke30
So u end up getting another rear housing for the gearbox?
1981 Ke70 Panelvan. Its Brown.
Nice van bought = purchase something brought = bringing an item to somewhere
Matt'S 7K Ke30
Does the gearbox have any crossmember mounting points or it mounted off the side of the box?
- Oke020
Ke30 Grille
It will be worth much more stock and look heaps better.
Flat Shifting
You'd walk??? :D Fifth or sixth, just the clutch.
Structural Braces Under Bonnet And Boot Lid Etc.
Id use sikaflex too
Is This The Wrong Forum For
I guess that was FONZY's celica?
V-tech Into Ke30
The w5* gearbox input spline suits the 2ZZ?
Ke30/55 Steering Connecting Rod Help??????
Or do you mean the drag-link between the steering box arm and the pitman arm :happy:
