rian
    1777
    37
Everything posted by rian
  1. There should be a vacuum diagram on the underside of the bonnet I think? That tells you where all the hose go.
  2. I was wondering how you had turned the wheel so far, I figured the control arms and tie rods must have been disconnected because I could see the wheel nuts were still on there. I wish that much lock was possible.
  3. I don't understand dildo shifters? They are so expensive, when a shifter extension is like $20 off ebay.
  4. When my year finished school in Byron, all the pleasant people moved elsewhere, all the assholes stayed in Byron, it seems to be the way it goes with Byron Bay. You need to get out of that shithole, get away from all the assholes.
  5. ʞ©$ɟing sweet!
  6. The tacho gets it's signal from the negative terminal on the coil I think.
  7. That's not even possible.
  8. KE10 front on a Publica ute.
  9. ^ KA24s came in Australian TRX Pintaras and Pathfinders.
  10. This is the only photo I have of mine, I'm not particularly fond of under the diff exhausts. I haven't measured it but I'm pretty sure the exhaust is illegally low, I'd rather have an over the diff exhaust and have the car being legal.
  11. That is the coolest factory paint I've ever seen! :o
  12. Balls
  13. Time for a service.... new errrrthang
  14. How much does it usually cost to hire out/go to a skid pan?
  15. http://www.youtube.com/watch?v=plPsnWFng0w
  16. Gross! However KE10s go alright with no roof:
  17. Someone please say something funny about scientology.
  18. Here is how I did it: This is the front door (the little electric motor is mounted in the bottom right of the door) And a close up The kit should have instructions in it on how to install it, it's not too hard, you just need some tools and the instructions. Then pull your door card off and figure out where you can mount it, drill some holes and screw it in on the bracket that comes with the kit.
  19. Suspension is looking the biz! Are you going to run the tie rod on the inner or outer hole in the steering arm? BTW one of your coilover springs is more tightly wound then the other?
  20. What's the new engine going to be?
  21. Wowzers
  22. Happened to me too, the car would run sometimes, sometimes it wouldn't. Then it just randomly died. The fusible link wire had broken but the two ends were still touching allowing power to pass through and every now and then over bumps and stuff the broken wires would stop touching each other and the car would stall.
