612 -
7
Everything posted by corollaart
Channel ten the so called home of motor sport has sold the live coverage to foxtel for most of the taxi series and f1 ,not sure about wrc. So if you follow any of these series best get foxtel if you want to see live or complain to 10 about it. Weak as channel 10 !!!!! end rant.
Whats going to become of topgear with out Clarkson? My THOUGHTS is that they will put some try hard to replace him and the show will stubble on for 12months then die. Much like the aussie version which just didnt have it (what every it is) I'm a fan of Clarkson i really think he makes it,with his smart ass comments and totally crazy antics. Thoughts!!!!!!
How Much To Extend Ke30 Lca's For 1-2Deg Neg Camber?
corollaart replied to megamannz123's topic in KExx Corolla Discussion
20mm gives 2.5 negative. -
4.7 or 4.8 best to ask the gravel gurus trd Tony or Craig supra. thats my suggestion. rob
Sorry about that Brent thought they where all the same (ke30 ke55) but not the case . Thanks for the correction Banjo. rob
- 19 replies
Just looking at the line you have a pic of i would say that its the main fuel line ,being on the right side . From memrory the fuel tank vent crossed over from the right side to left near the bell housing. The charcoal canister was part of the battery hold down clamp. I'm sure some one has a pic of the original set up. rob
- 19 replies
Yes there where two lines that returned to the front of the car . One the main fuel line. The other smaller one fuel tank vent to the charcoal canistar near the battery .
- 19 replies
40 DCOE X2 30 CHOKES 4.5 AUX CHOKES 115 MAINS F11 E TUBES 2.00 AIR JETS IDLE 50F9 40 PUMP JET
What Modification Did You Do For Your Car?
corollaart replied to justing's topic in Automotive Discussion
Ha we need more humor hear!!! I hope he doent take it to hard. Colin did that add KW ? :drinks: rob- 17 replies
- modification
- spark
(and 1 more)
Tagged with:
All i can say is becarefull ,remember poor man pays twice. Rob
Agree the lean option is great but jesus its not cheap!! Remember that the t50 box, is old now all of them.Most would be like WRX box ,never flogged ;) .But not made of glass!!!like subies. If your had it rebuilt i would take it back and ask some questions.
Out put shaft is different ,you can change the front yoke (same uni) The problem is that the bell housing will bolt up but leak oil ,a lot of oil . There was a write up on toyomods about it years ago. The shifter position is also different position about 17 -20mm foward. It all gets messy . I would try to ae71 or ae86 box save your self some grief or maybe a lot of sh#t. The box you proberly have is a ta22 box. rob
Good idea Kieth,you truely are a wizard !!! rob
Steering Conversion Help Ke70 Rack To Ke55 With S14/s15 Hubs
corollaart replied to monzo's topic in KExx Corolla Discussion
What about a write up Jono? If its legal of course.I think there would be a lot of owners including me that would love to get rid of my f##ked steering box. FAQ !!!!maybe??? -
Sports Steering Wheel For Ke30, What Are You Using?
I'm using the fake OMP 3rd from top it seems ok so far. You don't want any thing thats going to flex to much. don't use wood,!!!!!!! -
wHAT ARE TURBOS is it some new thing ,like yo yos. Like face tube thing!!! BA! it will be gone by xmas Hi Keith :wave:
HA Ha !sorry but the way you worded it is what YOU would expect .No hilux diff will bolt in but some are close RN40 is 1410 mm which is from memory about 15 mm a side wider than STD. There is a early hilux which is about 1360 ish which is close to std but you still have to cut off the mounts and re weld them. As well change the the drive yoke or drive shaft. But as its a hack job it doesnt matter ,as will have to be changed any way. good luck A
Its a how long is a piece of string question . 1;How much can you do your self? 2;budget how much can you spend on it? 3; Have you a shed that you can do it in ,tools to do the work. 4 Remember that the coupes are getting harder to find ,there for demand more money. 5 the old saying to build a great car, first start with a good car.(pay the extra for a good one to start not a rust bucket bondo bus) There a lot of helpful guys on this forum. I d say if you have the money to do it go for it. Sadly a lot of projects end half finished in the for sale section,thru lack of planning and funds. As far as how much it would cost depends on what and how far you go 100-50000 the skys the limit!!!!(do a budget)and try stick to it. Welcome to rolla club Rob
Nice find Seb, I have to ask ,have you got a celica addiction ??? How many have you got?Not that you could have to many ,but wow !!!! Nice shed !!!! cheers rob
Yep its all about having a go ,not letting mummy and daddy pay for it . Nice work so far ,should turn out good. Clapped out, 5 coupes !!!!give your self an upper cut bitch ha ha. rob
Just as styler said you need the hub that the bearing fits to ,as well as the clips which i no you can buy new . The box looks like the later type not early,although the bell housing looks like a t series.(t18 series 2) I would think buying a new clutch fork and hub would be long shot . I would ring up your nearest gearbox rebuilding out fit as most of them have a few old junkers under a bench some where. rob
I m sure that it will be a work of art .I remember reading that your 6th cage was your last Craig ha ha . So a display car only ,but with all the proper bits?? These builds of yours are a great read ,you do what most of us wish we could!! Rob
No worries Stuart ,my plan is to have a crack at wiring it up and see what happens . Ive got nothing to lose ha ha I think that i wouldnt be a good bomb defusing expert :drinks: As a mate of mine said how hard can it be,its only wires one ways right one way is or f##k,then the magic smoke escapes.
5K Distributor Igniter (picture below) 4AC Ignition Module, pink and green wire goes to distributor, two black wires go to VR sensor, although one of the black wires has a smaller terminal than the other (would the smaller terminal be negative?) (picture below) The 5K Distributor, the two wires from the VR sensor to the ignitor? (picture below) 4AC Module, 4 Terminals with numbers 3, 7, 15, 16. Terminal 3 is the black wire with the small terminal, 7 is the larger black wire these go to the VR sensor, whilst 15 and 16 (pink, green) go to the coil. Bosch 3820. (picture below) So I'm not sure which way the wires from the 5K sensor hook up to the 4AC ignitor, I'm guessing the smaller black terminal is negative.
