Main Page
(Redirected from Main Page New)
This FAQ had its origins in the Oldcorollas FAQ, maintained by Super Jamie.
Quick Navigation
KE1x KE2x
KE3x KE5x
KE7x AE86
AE8x AE9x
AE10x AE11x
General Tips
We try our best to keep the information here as up to date and accurate as possible, however this is not always possible. We encourage users to contribute their knowledge where they can while upholding a high standard of information. If you're not comfortable contributing directly, perhaps discuss your knowledge with others on the forum and suggest they make the changes for you.
Unfortunately due to spambots this wiki's signup page has been disabled. If you would like an account, please contact irokin via the forums or email [email protected]
What happened to the old Main Page?
It still exists, you can find it over here: Main_Page_Old. Please note that we're still working on migrating over some of the content. - irokin 19:30, 14 September 2012 (EST)
Whats new?
KE10 disk brake conversion 18/9/2012 Jono.C
TOSCO/TRD manual transcription 17/9/2012 irokin
Engine
Engine Blocks
Torque Settings
Camshaft
Carburettor
Cylinder Heads
Push Rods
5K Solid Lifter Conversion
Valve Clearances
Mounts
Sump
Oil Pump
Drivetrain
KE1x Rear Diff - convert to 4x114.3
Flywheel
Gearboxes
Manual Gearboxes
Automatic Gearboxes
Clutch
Misc
Make a KE10 cluster km/h
Exhaust
Boosted K motors
How To Fix Common Oil Leaks
Part Numbers
TRD Upright Kit
TRD K Motor Manual
Electronics
Alternator
80Amp Alternator Upgrade
Battery
Distributor
5K Electronic Distributor
Nippon Denso Part Numbers
Starter Motor
Fuel System
What fuel to use
Intake manifolds
Electronic Fuel Injection
Fuel Filter
Fuel Pump
Emissions System
What Is A Fuel Solenoid?
Nikki carb onto K motor
Suspension
Front disk brake conversion
Replacing front strut inserts
Tie Rods
Front Spring Upper Seats
Body
Engine
Engine Blocks
Torque Settings
Camshaft
Carburettor
Cylinder Heads
Push Rods
Valve Clearances
Mounts
Sump
Oil Pump
Drivetrain
Flywheel
Gearboxes
Manual Gearboxes
Automatic Gearboxes
Clutch
Misc
Exhaust
Boosted K motors
Part Numbers
TRD Upright Kit
TRD K Motor Manual
Electronics
Alternator
Battery
Distributor
Starter Motor
Fuel System
What fuel to use
Intake manifolds
Fuel Filter
Fuel Pump
Emissions System
Suspension
KE55 Front Strut Upgrades
KE30/35/36/38/50/55/55p Suspension
Body
Round Headlight Conversion
KE55 Boot Release
  • For AE71's please also see the AE86 section. Much of the information presented there is relevant to AE71s also.
Engine
4A-GE conversion
Engine Blocks
Torque Settings
Camshaft
Carburettor
Cylinder Heads
Push Rods
Valve Clearances
Mounts
Sump
Oil Pump
Drivetrain
Flywheel
Gearboxes
Manual Gearboxes
Automatic Gearboxes
Clutch
Misc
Exhaust
Boosted K motors
Part Numbers
TRD Upright Kit
TRD K Motor Manual
Electronics
Alternator
Battery
Distributor
Starter Motor
Fuel System
What fuel to use
Intake manifolds
Fuel Filter
Fuel Pump
Emissions System
Suspension
Brakes
Sigma Control Arms
Body
Panel Interchangeability
General Pages that don't fit anywhere else. Tech tips and the like.
This section needs to be blocked out yet (formatting).
Mechanical Tips
Removing Spigot Bearings
Fixing Rust
Decarbonising an engine
Emission Systems
Emission System Abbreviations
Emission System Components
Reference Material
Corolla Model Numbers
Books
What Carb is that ?
7K ECU Pinouts and Voltages
AE86 Manual (Dead)
KE70 Chassis Electrical System (Dead)
KP61 Starlet Manual includes 4KE EFI
Blacktop 4AGE Manual
History
The '60s
The '70s
The '80s
The '90s
Racing
Car Movies
Engineering your Car
Overview
South Australia
Victoria
